C3 Hibernation.
Old Jan 11, 2013 | 01:25 PM
spot99's Avatar
spot99
Default C3 Hibernation.
If your car is like mine (44 years old) and is a garage queen, how often should the beast be started during the winter months to preserve its vital juices and dangley bits?
Old Jan 11, 2013 | 01:50 PM
Mike Ward's Avatar
Mike Ward
Never. Let it sleep.
Old Jan 11, 2013 | 03:26 PM
scottw's Avatar
scottw
Once its put up for the winter, don't need to do anything till spring.
Old Jan 11, 2013 | 03:34 PM
1996Z15's Avatar
1996Z15
I think you meant to say; Never let it sleep. Drive it all through the winter on the days that there isn't any snow and it's nice and clear.
Old Jan 11, 2013 | 03:42 PM
qwank's Avatar
qwank
No, running it for a short period of time actually hurts more then just letting it sleep all winter.
Old Jan 11, 2013 | 03:59 PM
Dheista's Avatar
Dheista
Are there particular things that should be done prior to hibernation? Fuel stabilizer? Deflate tires slightly? Put up on blocks to remove pressure on tires? Battery tender?
Old Jan 11, 2013 | 04:37 PM
Mike Ward's Avatar
Mike Ward
No, I didn't. Mine sits for six months at time with no harm done. No gyrations or back flips required. This is not rocket science.
No magic additives, no blocks, no nothing other than a battery tender.
Old Jan 11, 2013 | 05:24 PM
Paul L's Avatar
Paul L
Mine sits in commercial storage from October to April. Oil is changed just prior to storage so fresh for spring start-up. It is not started: it is in "cold, non-start" storage but temperature controlled. I do use a form of Stabil but some do not think that that is necessary. For ~$5.00 I do it. Does not hurt.
Old Jan 11, 2013 | 06:44 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I snuck all the old cars out today Roads were clear and dry and I drove them each about 50 miles. Felt great. Unless you can really drive them let them sit.
I almost forgot how much fun they are to drive
Old Jan 11, 2013 | 07:01 PM
Big Block Dave's Avatar
Big Block Dave
No, I didn't. Mine sits for six months at time with no harm done. No gyrations or back flips required. This is not rocket science...
I like that!
Here on Long Island we do get a few nice days during the "off season", so I do enjoy taking mine out here and there on a clear day. Tomorrow we are supposed to get mid 50's.
My dad lives 150 miles north of here in NY, and keeps his C4 in an enclosed storage unit [truck body], as his weather conditions are probably more similar to yours this time of year. As he says "we have two seasons, 4th of July and Christmas"
Old Jan 12, 2013 | 09:42 AM
BARRY L-48's Avatar
BARRY L-48
Default Hibernation
I never put mine to sleep in the winter,drive it once in a while when roads are clear and dry, 60 degress today but the bottom falls out tomorrow,will be taking her out today to stretch her legs!
Old Jan 12, 2013 | 09:57 AM
71scgc's Avatar
71scgc
If you can't run it long enough to get all the water out of the exhaust, don't run it at all.
Old Jan 12, 2013 | 10:47 AM
qwank's Avatar
qwank
It was nice weather up here all week, but I never trust the salt on the roads. My car stays in the garage until March or April, no exceptions
Old Jan 12, 2013 | 04:20 PM
RMVette's Avatar
RMVette
Mine's sleeping at the moment...full tank of gas and a battery tender connected even though the battery has a disconnect switch:
Been nice here today...maybe I'll wake sleeping beauty up tomorrow!
Old Jan 12, 2013 | 08:22 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
I keep mine ready to go all the time, just cover it with three old blankets to keep the dust off. Battery tender and battery cut off switch and away we go.
Its a driver
Old Jan 12, 2013 | 09:56 PM
7T1vette's Avatar
7T1vette
I don't think I could go a whole month without starting the car. Maybe it doesn't NEED it.....but I do!
But, when it is started, I always run it till up to full temps for a few minutes.
Old Jan 12, 2013 | 11:21 PM
Brown Squirrel's Avatar
Brown Squirrel
sta-bil, plenty of gas, battery tender, car cover, and drive it when the weather cooperates.
To C3 Hibernation.
Old Jan 13, 2013 | 02:28 AM
Ibanez540r's Avatar
Ibanez540r
From the perspective of boat owners in the north, mine on Lake Erie, that go into cold hibernation for at least 6-7 months, usually do the following;
-Oil change before storage. They say the acids that have accumulated in the oil are not good to sit and eat at things all winter. Also has the benefit of being ready to go in spring.
-Either have a completely empty tank, or full (preferred). The temperature swings can cause condensation in the tank. We usually still treat with Stabil or the like.
-Run the engine once the stabil is in the tank long enough that it goes through the lines and carb to protect them as well.
-Run the motor and stall it out by spraying "fogger" in the carb. This coats the cylinders and eliminates that "dry" start in spring.
-Pull batteries and put on charge. (Or leave in on charge)
-A bunch of other stuff that doesn't apply to things that have wheels
..Twin 454 big blocks and that's my standard.
Old Jan 13, 2013 | 08:58 AM
keithinspace's Avatar
keithinspace
This is the key. PO of my car hadn't done much more than fire the car up and let it idle for a while once a month or so. He thought he was doing it a favor.
First, idle is actually hard on an engine. Better if the oil pressure is up, oil is being splashed onto the cam, pushed through the pushrods, and everything is well lubricated. Starting a cold engine and letting it idle doesn't cut it.
Second, my sidepipes are DESTROYED from all the water that sat in them. VERY obvious that the car was not run long/hard enough to burn the water off. As a result, my inserts are rusty piles of junk and the sidetubes themselves have more holes than porcupine's underwear.
If you don't run it...RUN it...not IDLE it...RUN it long/hard enough to get everything hot and happy from fan blade to exhaust tip, you're doing more harm than good.
Old Jan 13, 2013 | 09:01 AM
C3 4ME's Avatar
C3 4ME
I would think in Missouri, you'd get a nice day here and there as we do in VA. I've never put mine up for winter's storage. There's always a chance to take it out for a spin every once in a while around here.
