what headers are yall using?
Old Jan 13, 2013 | 11:51 PM
garym52's Avatar
garym52
Default what headers are yall using?
I purchased the 2" magnaflow pipes and mufflers from corvette central and installed them on my 79. Now I think I want to go with headers and I'm not sure which set will work with the pipes I have on the car. So I would like to know what you guys have used. Thanks!
Old Jan 14, 2013 | 09:34 AM
Sunstroked's Avatar
Sunstroked
A good question. I'm searching too. Has anyone used Stan's tri Y headers? http://www.stans-headers.com/headers.htm
Old Jan 14, 2013 | 10:53 AM
rafalc's Avatar
rafalc
None of the headers will be a direct bolt on (I dont think), unless you get the Patriots from CC if thats where you got your pipes. Other than that, with a little bit of cutting/welding you just need to worry about the reducer. Most headers will be 3" at the end so you need a 3 to 2 reducer.
I got the ceramic Headman long tubes, will be pairing it up with 2.5" Pypes system
Old Jan 14, 2013 | 11:22 AM
billcarson's Avatar
billcarson
i believe i have the same headers as rafalc and they have a transition piece that allows for some pivioting,which may help some.unlike the flange connection however these will not allow a but connection as the exhaust system must be moved to the rear to make that ball and socket style connection.
Old Jan 14, 2013 | 11:25 AM
billcarson's Avatar
billcarson
btw i do not recommend the ss flex connector as it will introduce some unwanted resonance.(it's one of those temp things that go on forever).
Old Jan 14, 2013 | 11:39 AM
Camivette's Avatar
Camivette
I have the bargain summit headers which I wrapped. Fit surprisingly well. Only troubles was the #4 plug. Went to header plugs. How do you like the sound of your exhaust with the magnaflo's?
Old Jan 14, 2013 | 11:56 AM
rafalc's Avatar
rafalc
fyi... pictures and video of the Headmans:
http://forums.corvetteforum.com/c3-g...project-5.html
Old Jan 14, 2013 | 12:17 PM
rogman16's Avatar
rogman16
McJack's "direct manifold replacement" shorties into 2.5 Allen's aluminized exhaust...
Rogman
Old Jan 14, 2013 | 12:42 PM
qwank's Avatar
qwank
I have the summit brand headers that i stripped and painted with VHT paint. They won;t bolt right up to the CC exhaust though. I have to use those flex pipes that Billcarson used then drove down to the exhaust shop to have then properly connect the headers with new pipes.
Old Jan 14, 2013 | 02:36 PM
hwcoop's Avatar
hwcoop
I used a set of Headman's hooked up to my 2.5" Corvette Central exhaust with a set of Magnaflows , perfect fit
Old Jan 14, 2013 | 02:55 PM
540 vette's Avatar
540 vette
Hookers
Old Jan 14, 2013 | 04:09 PM
7T1vette's Avatar
7T1vette
If you have 2" pipes/mufflers on the car, why are you even spending the money (and trouble) of changing to headers? There will be NO improvement in exhaust flow.
Old Jan 14, 2013 | 04:45 PM
garym52's Avatar
garym52
I actually lied earlier, I have 2 1/2" pipes. Will the headers help?
Old Jan 14, 2013 | 06:34 PM
redwhitekat's Avatar
redwhitekat
I'm putting on flowtech headers this winter hope their good
Old Jan 15, 2013 | 05:35 PM
glen242's Avatar
glen242
I am using Dynomax ceramic headers on my '76 383 with TF 23* angle plug heads. No clearance problems and regular plug lengths, FR3LS, are accessible without a problem.
I have had these headers for about 9 years, but I don't believe they are still manufactured, unless they are sold under a different name.
Any headers you use, you will be ahead of the game by using Stage 8 locking bolts. I have had no exhaust leaks over the years, when using FelPro gaskets. Installed correctly, there will be no maintenance, i.e. re-tightening.
Old Jan 15, 2013 | 06:28 PM
redwhitekat
Did you car improve performance with these new headers ?? I'm curious how mine will perform
Old Jan 15, 2013 | 07:54 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
To what headers are yall using?
Old Jan 15, 2013 | 08:45 PM
Lupigiato's Avatar
Lupigiato
Originally Posted by 540 vette
Hookers
Old Jan 15, 2013 | 08:56 PM
parkerracing's Avatar
parkerracing
Stahl headers and sidepipes.
Old Jan 15, 2013 | 09:03 PM
johnnyw's Avatar
johnnyw
I have hookers, they came on my car, but way back in the day they made good headers and the ones on my car seem to be very good also.
Johnny
