Reconditioning Rally Caps
For the sides of the ornament, I first tried spraying the entire surface and then removing the paint from the ribs using the lacquer thinner technique described above. However, I couldn't keep from touching the paint between the ribs with the rag. While it didn't remove the paint to the chrome, it did leave "wipe marks" which left the paint dull. So, I scrapped that idea. (I did try the razor blade method, but discarded it because of pitting along many of the ribs. I also had difficulty getting the desired chrome "exposure" along the rib. Multiple passes would be required while rolling the blade to each side of the rib. Too tedious for me!) Instead, I masked off each rib with a 3.5mm strip of masking tape that I cut. (I laid a 12" strip of 1" wide tape on a piece of glass. Using a straight edge and a sharp exacto knife, I cut the strips. If I remember correctly, I then cut the tape crosswise at 3" intervals. This gave me enough strips to do half an ornament (40 ribs per ornament for inquiring minds). I made a jig out of scrap lumber to hold the ornament while applying the tape. I used the exacto knife to lift one end of each tape strip and small tweezers to grip the other end. This allowed me to keep the tape taut while applying it to a rib. When finished with the ribs, I taped off the ends of the ornament above and below the ribs. Since the exposed chrome ring at the base of the ornament is very narrow, I cut long strips of tape. The narrow strips seemed to adhere better than a 1" wide pieces.
The final step was to try my hand at buffing the SS. This, I found, is more art than science. I say this because I had no prior buffing experience. It was definitely a learning process. I buffed those caps so many times that I finally had to tell myself "Good enough"! While they are many times brighter than when I got them, I'm still not satisfied with them.
This turned out longer than I had intended. But, if anyone can extract anything useful from it, great. While I didn't document the process with pics, I do offer a few "after" pics.
I find that this works very well. And after doing 4 or 5 ribs, it becomes relatively easy to get an even flow of paint and a very smooth and consistent paint line without any waviness to it.
Tedious worrk but the results are worth it. Cheers,
If I charged by the hour, I'd be laughed off the forum. However, I might set up a booth at B-J; those guys have plenty of money!!
