Rear defog switch help
Old Jan 18, 2013 | 08:04 PM
Bremquest's Avatar
Bremquest
Default Rear defog switch help
My rear defogger switch seems to be broken and I cannot seem to find one on any of the repo websites. Can these be repaired? Anyone else run into this issue?? (1969)
Old Jan 18, 2013 | 08:47 PM
7T1vette's Avatar
7T1vette
Depends on what's wrong with it. If the contacts are just burned/carboned-up, clean them. If the mechanism is just worn out, no.
If you need to find a similar replacement, Google "rocker switch" and include current requirement [ie, 30 A], whether it is lighted when on, and/or color of the switch to help narrow the search.
When you find a manufacturer that makes a similar product, write down the item designation number. Then call Newark Electronics or other mail order electrical component supplier to see if they can order just one.
This may be a good place to start:
http://www.newark.com/rocker
Old Jan 18, 2013 | 10:57 PM
Bremquest's Avatar
Bremquest
Mine just spins...so sounds like it's worn out :/ total bummer. I want to keep this looking original.
Old Jan 18, 2013 | 11:30 PM
7T1vette's Avatar
7T1vette
Oops! I thought they were rocker switches. You probably can find a similar type switch with the same diameter shaft...then put the original **** on it. Doubt anyone could tell the difference.
Old Jan 19, 2013 | 04:23 PM
Bremquest's Avatar
Bremquest
Wow not a lot out there for sale. Maybe I can find one similar and modify like you said for the **** to fit. Nuts :/
Old Jan 20, 2013 | 01:59 AM
7T1vette's Avatar
7T1vette
Try Radio Shack. But, make sure it will handle at least 20 amps. (30 would be better)
Old Jan 20, 2013 | 02:14 PM
Bremquest's Avatar
Bremquest
Jeez I feel like I haven't seen a radio shack in ages! They must still be out this way haha. Thanks for the advice
Old Jan 20, 2013 | 03:39 PM
oldsarge's Avatar
oldsarge
Try Paragon. Ask for the vintage dept., they have lots of used parts available, you just might get lucky.
To Rear defog switch help
