Idle speed changes on me
Old Mar 17, 2013 | 11:19 PM
COPO TOM's Avatar
COPO TOM
Default Idle speed changes on me
I have a Q-jet that has been re-built. Also had new bushings put on the primary throttle shaft. Start the engine up warm and it idles fine at 700 rpm. Drive down the road and back and the engine wants to idle at 1000 to 1200 rpm. Push the secondary air valve open and the engine goes back to its 700 rpm idle speed. Let the air valve close and in 10 to 15 secs. the engine will start back to 1000 to 1200 rpm idle. Turn the engine off and re-start it and it will idle fine at 700 rpm,... until I drive it. Help please. Thanks
Old Mar 18, 2013 | 12:28 AM
Shark Racer's Avatar
Shark Racer
Is your choke working? What kind of choke?
Old Mar 18, 2013 | 09:30 AM
exposingtime's Avatar
exposingtime
2015 C3 of the Year Finalist
Fast idle cam needs some adjustment.
Old Mar 18, 2013 | 09:37 AM
COPO TOM's Avatar
COPO TOM
Yes the choke works fine. It is the stock divorced choke. I will take a look at adjusting the fast idle cam and report how that does. Give me a day. Thanks
Old Mar 18, 2013 | 10:13 AM
COPO TOM's Avatar
COPO TOM
Let me also say that the engine warms up fine when cold, and the engine/car runs great. It is only the odd idle situation after the engine has warmed up.
Old Mar 18, 2013 | 12:19 PM
7T1vette's Avatar
7T1vette
One of three things is happening:
1. You have some binding in the throttle cable or carb side linkage; find it, lube it, and/or add a stronger return spring.
2. Your floor mat is laying on the accelerator pedal.
3. The carb is not 'centered' on the intake manifold and the throttle plates are rubbing on the bores in the manifold. Loosen the carb mounting nuts, wiggle the carb to become more centered, then tighten them back down. Now try "exercising" the throttle to see if it is any better.
4. There could be other possibilites...I just couldn't think of them.
Old Mar 18, 2013 | 01:19 PM
F22's Avatar
F22
Yep, mine was number 3. The rear secondaries wouldn't quite close sometimes after opening, because the sides of the plates would stick just a little. With the extra air coming in, the idle would be higher than normal, but once it closed properly, then it was good.
You could also rotate the linkage against the stop when it's idling high and/or press on the butterflies and see if you hear a change in the RPM level.
Old Mar 18, 2013 | 01:52 PM
COPO TOM's Avatar
COPO TOM
Pressing on the primary throttle arm of the carb. (the one the throttle cable goes to) does not help, and I can see that the arm is against the set screw. So it should be back to the original setting of 700 rpm. I found that opening the secondary air valve brought the engine back to normal idle by pushing it open to look and see if the secondary throttle blades were closed. They look to be closed and pushing on the secondary throttle arm does nothing to help return the engine to normal idle. If I watch the throttle arms when the engine is shut off I see no movement. But when the engine is immediately re-started it will idle at 700 rpm. Thanks for the ideas.
Old Mar 19, 2013 | 03:01 PM
COPO TOM's Avatar
COPO TOM
I put an old Q-Jet that I had on the engine, and it idles great. So I guess I better see what's wrong with the re-built Q-Jet. That wasn't suppose to happen. Trying to get one fixed-up and running good and more problems.
Old Mar 19, 2013 | 04:11 PM
dc502's Avatar
dc502
send Lars an email he is the qJet expert.
Old Mar 19, 2013 | 04:29 PM
randommj's Avatar
randommj
Is he still retired from tuning carbs? I need someone to tune mine up but no one wants to touch a Q-jet.
Miles
Old Mar 19, 2013 | 04:48 PM
dc502's Avatar
dc502
Miles
yes he is doing it still you will need to send him an email to go over the details. I just emailed him last night and he said he had a few weeks lead time and I might want to hold off a week or two before i send it to him.
Old Mar 24, 2013 | 05:17 PM
COPO TOM's Avatar
COPO TOM
I am going to send my Q-Jet throttle plate off to have bushings put on the secondary throttle shaft. Then I will try this again. Q-Jet is a great carb., I just need to get this idle situation fixed.
Old Mar 24, 2013 | 05:33 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
hmm, float and fuel pressure.
vacuum leak.
To Idle speed changes on me
