door adjustment help
I believe my passenger side door (72) is sagging a little and would like to know the procedure to adjust it so the handle doesn't stick when trying to open it. I did a search on "door adjustment" and "door lifting" but didn't fond what I need. Any help would be appreciated.
Thanks,
andy
Otherwise, I would mark the door latch striker position, remove it and start playing with the pillar bolts, I have found these bolts to give me most of the adjustability needed. A helper to hold the door is nice, putting shims under the door along the rocker panel to temporarily hold the door where you want it works to.
Now if you you have removed the body from the chassis at some point, it's entirely possible a little body shimming is required, but we don't want to go there just yet.
Once the door fairs in nicely, reattach your striker, it may be necessary to move it from its old location a bit.
