71 lt-1
SO, am I right in thinking all ain't right with this LT-1 on eBay that's advertised as a matching numbers car.
http://cgi.ebay.com/ebaymotors/1971-Chevrolet-Corvette-Convertible-LT1-Very-Original-Car-/330897048819?pt=US_Cars_Trucks&hash=item4d0b0044f3As I said, I'm no expert, but isn't that a 327 under the hood?
LT 1 is a package
to include: big block half shafts, 6500 redline, bigger rad
4 speed
rear end
350/330 HP
Solids and steel crank.
if my memory serves.
been a while.
No 327 in 71.
Either way, it's not completely legitimate.
P.S. Another look shows the block stamp with a different VIN derivative than the windshield post plate.
you see the block numbers?
I did not know there were two grades of half-shafts. Can you possibly link me to some reading on this (so as to save yourself the typing?).
It raises a lot of questions for me--one being, do people with a SBC that upgrade to a BBC, or go (potent) crate motor, have to upgrade their half shafts too?
Are catastrophic failures common, for those that don't upgrade?
I'd like to educate myself on the difference in specs, and how to tell one from the other.
Thank you for entertaining a noobs questions.
Peter
65-74 big blocks, as well as LT-1's, came with different stub axles, than most other small blocks. On the big blocks, the U-joint is attached to the stub axle by a cast iron cap, and 2 bolts. On regular stub axles, the U-joint is secured by a formed strap that wraps around the U-joint, and 2 nuts. The stub axle, is the short side yoke, on each side of the rear end, that the half shafts attach to. Sometimes the big block stub axles, are referred to as heavy duty ones.
Around 75, Chevrolet switched to larger diameter half shafts. People often think that these later larger half shafts are stronger. It's my understanding, that the larger diameter shafts, are made from thinner material, and are no stronger, than the earlier small diameter half shafts.
I've spoken to people. who mistakenly believe that the later large diameter half shafts, where for big blocks. They never were used on a big block.
The weakest link in the rear drive train, is probably the U-joints, a lot of people use. The factory used solid ones, without grease fittings. The aftermarket ones, with the grease fittings, may be more convenient, but usually aren't as strong. I know a lot more people who have broken U-joints, than have ever broken a stub axle.
There are now U-joints with the grease fitting, in the end of the U-joint, instead of in the X. These are stronger, but still not as good as the solid ones, at least in my opinion.
I believe you'll find that the half shaft itself was the same for sb/bb cars and also of reg. suspension and hd suspension.
The difference was that sb low horsepower cars had a strap and nuts for the u-joint connection while the sb high performance engine and the bb engine used cap and bolts.
Many of the vendor's catalogues show the 2 different parts.
Hope this helps.
Regards,
Alan
PS: Sorry GB answered while I was looking for my pictures! Too Slow!
Here's the std sb u-bolt and nuts.
Here's the cap and bolt on a bb.
I copied into a word doc as follows (on #8 I thought the 70 LT-1 had a different part# intake, the 71 72 had the 3959594) (much thanks to whoever posted this):
There are a few things that only a LT-1 would have , some are pretty easy to change out and some are not very easy at all.in no piticular order.
1st. No 1970 or 1971 LT-1 had A/C
2nd. Emmission sticker on fire wall behind master cylinder should have letters AX on upper left corner for a 71.
3rd. All LT-1's are 4 speeds. (M20 was std , M21/M22 were optional)
4th. Tach has 6,500 RPM red line on 1970 & 1971 and on 72's w/o AC
5th. All 71 LT-1's came with A.I.R. system. If removed should still have manifolds with holes for the tubes, Car may have headers and if so ask to see old manifolds.
6th. LT-1's had copper radiator W/O a overflow canisiter on the passanger side fenderwell. There should also be no holes whers one had been mounted.
7th. All 70 / 71 LT-1's had Tranisitor Ign. system. That may have been removed. But if it is removed look for the 3 holes on the front face of the driver side inner fender well where the Amplifer box was mounter.
Take a flashlight and look in front of the front wheel or open hood and look at it from the front side. 2 holes on bottom and 1 on top.
8th. Should have a Winters snowflake intake manifold with casting # 3959594
9th. LT-1's had a Holley carb. so there is only 1 fuel line , no return line like a quadra-jet carb. Look along frame rail on passanger side for the single line. Also the fuel tank is different. There should be no nipple on the passanger side, side wall for a return line.
If you lay on your back under the rear wheel you can reach your hand up and feel for an indention on the passanger side. If there is a nipple that is capped off , then beware.
Also the single fuel line on a LT-1 was not the same line that was used to feed fuel on the 2 line set up. So if someone removed the return line the look of the 3/8 line is still different. Not a big difference but if you can look at a car with a 2 line set up then you can see what you do not want to find.
10th. LT-1's had solid lifters , but if the car does not then that is not to big a red flag. Many people do not like them and may have replaced with HYD. lifters during a rebuild.
11th. The hardest to fake and most expensive would be the 4 bolt main block. No # on the outside of the block can verify this.
Only way to verify is to remove the pan or have a lighted optical viewer and remove the drain plug.
12th. LT-1's use 2.5" exhaust pipes like the big block cars. But the manifolds were still 2" set up. So the pipes flair from 2 to 2.5" about 6 inches from the manifold. The exhaust hangar at the trans is also different. Look on line at the Corvette Central site and you can see both 2" and 2.5" hangars.
13th. As I recall the highest rear end gear was 3:36 if trans was a M20
And id Trans was a M21 or M22 the 3:55 was highest gear
M20 3:36 Economy
3:55 Standard
3:70 Performance
M21 / M22
3:55 Economy
3:70 Standard
4:11 Performance
14th. The 71 /71 LT-1 Aluminum valve covers should have a rubber oil cap not a twist in. These covers are very hard to find. All the catalouges sell the twist in cap style.
15th. LT-1's have the same heavy duty half shaft retainers as big block cars. look at the rear end side yokes, there should be caps with bolts. Base cars used U bolts with nuts.
16th. The rocker arms have a letter O stamped in them.
17th. The balancer on the crankshaft is an 8" unit not a 6"
That is all I know of. and you could not fake all of this and sell a car for a mid 20's price and be worth the effort / expense.
So until someone finds the lost records from St Louis anyone buying a no base model car will be going out on a limb at little unless you are buying from the original owner.
Peter
The only difference with 'big block' half shafts was a narrow band of bead blasting that was done at the welded joint where the tube meets the yoke.This feature gave a subtle difference in appearance that was lost as soon as corrosion set in.
Dear mrmagrath,
It is a original motor all dates and #s are correct.
- allcorvettes2008
It looks to me like the suffix code is HT (?).
66-67-68 327 L-79 350 hp.
Looks like it WAS an LT-! many years ago.
Regards,
Alan
(I agree that the speedo shows 36k miles...or 136K miles....or 236K miles or....)
