Side pipes
Old Mar 28, 2013 | 05:03 PM
55Trucker's Avatar
55Trucker
Default Side pipes
I've got a 68 427/435 coupe. My question is, were side pipes available from the factory? When I look at the various parts places it seems like the side pipes for this car had a fiberglass cover. Is that correct? How were the covers painted at the factory?
And finally, if I wanted to go with aftermarket side pipes (like Hooker), are points deducted when the car is judged? I'm putting in a lot of effort into restoring the car to the way it looked when it was new, but things like side pipes I really like the look of and wondered how much leeway I have in trading nice looking off against correct.
Thanks!
Old Mar 28, 2013 | 05:21 PM
69Pman's Avatar
69Pman
Option N14 side mount exhaust was only available as a factory option in 69. To install the 69 factory sides, you'd have to cut a small piece of fiberglass at the very front of where the rocker panel covers so that the exhaust cover can properly fit. The original covers weren't fiberglass but you can buy them in fiberglass and have them painted if you'd like.
Also, the rear cutouts for the original exhaust will have to be filled or you can chose to leave the rear panel alone. You can also buy aftermarket panels that fill in the cutouts, you'd have to fit it and get it painted to match.
phil
Old Mar 28, 2013 | 05:26 PM
69Pman's Avatar
69Pman
As to the judging...If you want to keep the car original for judging purposes then I would stay away from the pipes. BB 68...awesome car as is!
Old Mar 29, 2013 | 11:40 AM
Alan 71's Avatar
Alan 71
Hi 55t,
If you're referring to NCRS Flight Judging it's pretty easy to estimate the point loss by looking at the judging sheets.
In brief, it will be judged as though there's no exhaust system on the car. So you lose the points for the under car system that isn't there, (pipes, mufflers, tips, hangers).
In addition, the rocker trim isn't there so those points are lost too.
Then depending on how you've treated the rear valance you might lose some points back there too.
Also remember, if for a certain item you lose all the originality points, you lose the condition points too.
I estimated what the point loss would be for my 71 when it had 69 side exhaust on it and I 'think' it was about 100 points.
The cars DO look and sound great though with the 69 side-exhaust!
Regards,
Alan
Added: The aluminum 'shields' were chrome plated, with the grooves between the 'fins' on the center section, and a tiny bit of the front and rear sections, painted a dark gray.... maybe the same gray that was used on the center front grill in 70-72.
The portion of the insulator that's exposed was painted semi-flat black. The covers were mounted with phillips oval head screws that were black oxide.
Old Mar 29, 2013 | 12:14 PM
javaman's Avatar
javaman
2025 C6 of the Year Finalist - Modified
2021 C6 of the Year Finalist - Modified
Next years project...find an original,complete set! Next years dream, find that set for under 1k!!
Old Mar 30, 2013 | 05:55 PM
55Trucker's Avatar
55Trucker
Thanks for your your responses!
Ok, two more questions regarding originality:
1) Are points deducted if you have the front fender side louvers installed? Those were only available on 69s, but I imagine 68 owners installed them on their cars, too.
2) Ditto for the Stingray emblem on the front fenders?
Old Mar 30, 2013 | 06:52 PM
Alan 71's Avatar
Alan 71
Hi 55t,
The NCRS Flight Judging Standard is based on the the car as it was DELIVERED to the FIRST owner, MINUS any DEALER installed or inspired options or extras.
So a 68 would not/could not have had the pipes since they weren't available yet.
The same thing is true for the Stingray script and the side louver trim.
Regards,
Alan
To Side pipes
