About To Start Stripping!!!
My '69 I believe was gold before they poorly painted over it with blue. Using a razor blade I can easily get rid of the blue.. but there's a smooth brown layer under that(that I thought was the gel coat but just found out there's no such thing.)
I can try to razor blade under that(maybe with the help of my heat gun) but it seems pretty thick and not razor blade-able.
Edge around the hood
Between headlight and hood...
Color difference, and a blurry shot of the poor cracking blue paint
The T-Top
You can easily see the terrible cracking paint and poor paint job the PO must have done.
Just want to know if when I razor blade it should I see fiberglass?
If I'm eventually going to paint his thing do I want to get it down to bare glass anyway right? so the primer or not it needs to go?
I was all set to do the razor blade method but as it turns out...it sucks.
It can get the top blue layer off...and that's it. and that blue layer is so thin there's almost no point in trying to razor blade it off first.
I think I'll have better luck with chemicals or even the controversial sanding
I had the same thick brown primer under my car's second paint job, which was utterly impervious to stripper, so once I had either scraped or stripped down to that I sanded through it with 80 grit paper.
In the absence of soda blasting (which is the ONLY kind of media blasting that is safe for fiberglass) the fastest way to strip paint from one of these cars is with aircraft or fiberglass-safe stripper, but even that won't get it all. It will get about 80%, but the rest is just long, grueling, frustrating hours and hours of hand sanding, and with a car that has blistering, delaminating paint like your does I really think removing it all is going to be the only safe route.
Just keep at it, don't quit, and you'll get there.
80grit sheets or blocks? do you use a device that hold the sheets?
Or by "hand" sanding do you use an orbital?(i've seen a lot of thread bash that method but not sure)
How many sheets of sandpaper will it take so I know how much to order?
This car is for learning purposes so there's NO chance I won't attempt this myself
I'll paint it at least once, then I'll see how good/bad it is if i'll want to do another lol.
As far as how much sandpaper...I just kept buying it a couple packages at a time until I was done, I probably went through 10 or 12 packages of 80 grit paper.
The biggest thing working against me was age and not enough free time-for the first year of the project I was working 10 hours a day and Saturdays so there just wasn't that much free time. If I'd been 10 years younger and had Saturdays to work on it I would have finished it a lot sooner...
Is there a different kind that is safe or it's just all safe?
I like the idea of Citri-strip over other brands as it seems like it would be less gross and nasty to deal with.
The brown stuff looks like lacquer primer. You should find more of it under the gold paint. The lacquer primer is usually the hardest part to get off. Scotchbrite and lacquer thinner is what's used. It's a lot of work.
I would use a razor blade knife and try to remove what you can. I agree...keeping the angle, pressure and the way the razor blade must follow the panel (so you do not allow the outer ends of the razor blade to gouge into the fiberglass) is a bit tricky. But if you have eyes and can make sure you keep the blade perpendicular to the curves and reverse rolls of the body...you should not have an issue. Just make sure you burnish the blade ( running is backwards on a towel on a flat surface).
Buy using a razor blade....it can greatly reduce the use of stripper due to removing paint and not having to deal with the mess. Because it will get messy if you use chemical stripper.
Kleanstrip offers a stripper for lacquer. I use it and also Aircraft Remover stripper. I have never had a problem because I watch and test to make sure the time that is needed to soften and lift the paint off the fiberglass WITHOUT damaging. I do not apply it and then go to the "movies". AND when I re-apply either stripper...I am NOT "*****-NILLY" about it. I am very careful to not slap the stuff all over an area I just stripped. Also...I use automotive grade lacquer thinner and rough steel wool to aid in removing any areas that need a little help to come off. Then I carefully wipe the panel off and then wipe it again with clean lacquer thinner and paper towels ( Bounty). The steel wool WILL NOT damage the fiberglass. I also use red scotch brite.
If you use chemical stripper you NEED to obtain and USE the correct gloves that are methylenechloride resistant (MeCl). Also make sure you are in a area with GOOD air flow. DO NOT strip out in the sun. Apply the stripper in ONE DIRECTION and do not brush back and forth... because this causes the skinning properties of the stripper to be open and the ability of it is lessened due to breaking this dull skin that will show up after application. I sue plastic "bondo" spreaders to aid in removing the stripper...and in many cases...due to me applying the stripper thick...I can move that stripper to the next area beside it and keep using it until it will not do anything at all.
I have chemically stripped more Corvettes that i can count...so it can be done...like many others also have done. Just remember...GRAVITY...start at the top and work down and do not get too far ahead of yourself. Keep it under control and you will/should be fine.
DUB
Right now, before getting started, I am trying to get educated, much thanks to this forum!
....I've stripped four Corvettes and used Evercoat One-Strip. Took appx 5 gals per car. Stuff is thick and gooey so it will stay in place on vertical panels. Did one panel, door or hood at a time. Did each Corvette in under three weeks. On the vertical panels, as stated work top to bottom. I had several sheets of newspaper under each panel as I went, then when I was done with that particular panel, just rolled of the newspaper with all the goo and carefully disposed in a plastic trash bag.
