Ever use this insulation????
Old Apr 11, 2013 | 10:58 PM
quickcat's Avatar
quickcat
Default Ever use this insulation????
I am working on a 70 that I am bringing back to driving condition for my wife. I want to insulate the interior for heat and sound but am not sure what product will get the job done.
Has anyone tried using this stuff from Mid America?
http://www.mamotorworks.com/corvette-4-380-1548.html
Nice kit but seems like factory stuff and may not keep the heat out like I am hoping.
I was also thinking about this kit from Jegs:
http://www.jegs.com/i/JEGS+Performan...70500/10002/-1
Of course there is dynamat. I am going to take measurements to see how much material I will need to do the job so I can come up with a cost.
I am looking for some experience that can guide me away from a product that won't perform. Thanks.
Old Apr 11, 2013 | 11:17 PM
20mercury's Avatar
20mercury
Default My 2 cents
I used the bubble wrap stuff from Home Depot or Lowes.
It has an aluminum foil color and is basically like bubble wrap with trapped air bubbles in plastic for insulation.
Cheap and used a pair of scissors to cut and fit. Made a world of difference in my 76.
Old Apr 11, 2013 | 11:24 PM
Vette5.5's Avatar
Vette5.5
Another place you might want to check with, is B-Quiet.com. For $10 bucks they'll send you a sample card with some of thier products. I did this for a friend, and product quality looks good, with good prices. Worth checking into. Place is in Canada, so shipping takes a bit longer.
Old Apr 11, 2013 | 11:34 PM
7T1vette's Avatar
7T1vette
What heat source(s) are you trying to eliminate? If you don't know [for sure] where the unwanted heat is getting into the interior, installing 'stuff' is a bit premature. Diagnose the problem(s), THEN develop a solution.
There are at least a dozen 'usual and customary' ways for unwanted heat to enter the interior. Floor insulation will help with a couple of them.
Old Apr 12, 2013 | 12:04 AM
BeansWorld's Avatar
BeansWorld
Dynamat is more of a sound / vibration dampener, this shouldn't be confused for heat protection devices (think quality car audio). I've heard good things about the Mid America etc packages, though the Home Depot material will work just as well provided it's applied and installed correctly.
Check out the various threads, you'll see there are specific fixes for specific issues.
Regards,
Eugene
Old Apr 12, 2013 | 01:11 AM
BOSTONCAMARO's Avatar
BOSTONCAMARO
ive always used dynamat...but in corvette using the reflectix from home depot..easy to use and inexpensive
Old Apr 12, 2013 | 08:00 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
FWIW: the Mid-America kit is C3 specific and would save you some time trimming and fitting. Skip the JEGS - it's generic universal and there isn't much "universal" in a C3.
Old Apr 12, 2013 | 08:07 AM
woodvette03's Avatar
woodvette03
i believe dynamat makes a heat shield. i called them once for this exact situation. they told me what products to use to cut down on heat and road noise. expensive stuff. i never got around to doing it though.
Old Apr 12, 2013 | 08:25 AM
Garys 68's Avatar
Garys 68
Ebay Fatmat on the floor/doors for noise. Lowes reflexit for heat over that. Then jute backed carpet. Inexpensive, very effective for both heat and noise.
Old Apr 12, 2013 | 09:26 AM
ezobens's Avatar
ezobens
Wouldn't you want to install the heat barrier first and apply the sound deadening material on top of it?
Old Apr 12, 2013 | 12:53 PM
sstopczy's Avatar
sstopczy
I put a shut off valve on the hose to my heater core and the heat was drastically reduced. Cost $4 at the local hardware store.
Old Apr 13, 2013 | 08:45 AM
quickcat's Avatar
quickcat
I have thought about adding one of these..... how do you control it? If I put one in I would like its operation to be integrated into the existing heater controls.
Old Apr 13, 2013 | 08:52 AM
sstopczy's Avatar
sstopczy
You can't control it through your normal heater controls, you have to pop the hood to open or close the valve. If your heating system is functioning properly, it should automatically do this, but I don't drive when it's cold so the heat controls don't mean much to me.
Old Apr 13, 2013 | 06:55 PM
Garys 68's Avatar
Garys 68
The fatmat is a heavy adhesive backed material. You need mass to decrease sound. Adhering to the panel decreases the resonance. Fatmat needs to adhere.
Temp insulation is the opposite, low mass. The reflexit is foil with air between. That goes on top of the fatmat if you want to use it.
Old Apr 13, 2013 | 08:44 PM
Stroh's Avatar
Stroh
Dynamat for sound.. Reflectix for heat... No regrets. Dynamat is expensive but definitely worth it. Reflectix is inexpensive and certainly has reduced the cockpit heat to nearly nonexistent. Both good stuff. Good luck
Old Apr 14, 2013 | 12:38 AM
redman76's Avatar
redman76
St. Jude Donor '09
This is what I used and worked great. I compared against Dynamat and looked the same material/thickness, but much cheaper.
Old Apr 14, 2013 | 12:53 AM
junkman123's Avatar
junkman123
[QUOTE=quickcat;1583615955]
i am planning on using this kit...but only because the gave it to me when i bought the new carpet set he had for sale,it feels like a pretty good addition to the fake "horse hair" on the back of the carpet which is 1/2" thick itself.
To Ever use this insulation????
