getting back on top
Old Apr 16, 2013 | 08:49 PM
benniebernard's Avatar
benniebernard
1st Gear
Default getting back on top
I have a 1976 corvette. I believe it has set long enough for the gas to go bad. I would like to drain the fuel tank. I don't know where to start.
Old Apr 17, 2013 | 08:37 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Pumping it out might be easier than trying to drain it. You can get a cheapo electric landscape pump designed for garden pools at WalMart. The pump won't care if it is pumping water or stale fuel.
Old Apr 17, 2013 | 09:10 AM
AirborneSilva's Avatar
AirborneSilva
Or you can jack it up in the back then take the fuel line off the fuel pump (be sure you have something to catch the fuel in), and just let gravity do the work for you
Old Apr 17, 2013 | 12:49 PM
BKbroiler's Avatar
BKbroiler
Do NOT use an electric pump to pump gasoline from your tank. There is a huge risk of an explosion. (I thought everyone knew that.)
Old Apr 17, 2013 | 12:55 PM
Easy Mike's Avatar
Easy Mike
Suit yourself. It's a sealed pump and actually immersible. I've used mine a couple of times.
Old Apr 17, 2013 | 01:01 PM
gungatim's Avatar
gungatim
I have had to drain a few cars that had bad gas, as was posted above, disconnect the line into the pump, get a hand pump from harbor freight, the red plastic one for $5, you can slip the hose over the line and pump by hand until you get a siphon started.
You could also stick a rag around a blow gun in the filler neck and use an air compressor and blow some air into the tank to force the liquid through, but if you don't know what you are doing, you could split the tank, so unless you've done it before I don't recommend that method for the first timer.
nothing wrong with an electric pump as long is it is rated for gas, that's how just about ALL new cars pump fuel for the last 25 years...
Old Apr 17, 2013 | 03:58 PM
BKbroiler's Avatar
BKbroiler
I know that. A "cheapo electric landscape pump" is not suitable for pumping gasoline.
Old Apr 17, 2013 | 05:31 PM
62corvette's Avatar
62corvette
If you have a compressor, get some clear plastic tubing at Home Depot, etc. make a small hole in it about 6" from the end. Put the other end in the gas tank. Stick the end with the hole in it about 5" into your gas can on the floor. Stick the end of your air hose blow gun into the small end hole in the side of the tubing and blow toward the short end. You will be astounded how quickly it will begin siphoning. I just did that with 13 gallons put in the tank on july 16, 1980. Had 3 gas cans available, and it probably didn't take but 7/8 minutes. You can use rubber hose, but with about $4 worth of plastic tubing, you can see what's happening. It was liquid varnish with a reddish tint.
To getting back on top
