C3 Bezel Pricing ?
Old Apr 20, 2013 | 07:41 PM
masrik's Avatar
masrik
Default C3 Bezel Pricing ?
Can someone explain to me why the same bezel ... but with a CD cut out for DIN as opposed to the **** Stereo cut out is so much different in price ? It is just a cut out right ? Cant a Dremel fix this ?
http://www.ecklerscorvette.com/corve...1978-1982.html
http://www.ecklerscorvette.com/corve...1978-1980.html
Old Apr 21, 2013 | 07:49 AM
mark6669's Avatar
mark6669
It would take more than a dremel but I think there is some greed involved, I have always wondered the same thing.
Mark
Old Apr 21, 2013 | 09:13 AM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
Because e one at the higher price has the word "custom" in the description.
Add another hundred bucks and you can get a stereo with it
Terry
Old Apr 21, 2013 | 09:25 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I don't know the answer but I know we have them for 158.00
http://willcoxcorvette.com/advanced_...s=dash%20bezel
Old Apr 21, 2013 | 09:35 AM
masrik's Avatar
masrik
Ya Wilcox is cheaper then Ecklers but still $100 more for 2" on each side ?
Ugh
Old Apr 21, 2013 | 09:49 AM
0Willcox Corvette
Former Vendor
I don't make them, set the price, or understand why myself...
Old Apr 21, 2013 | 09:52 AM
vettebuyer6369's Avatar
vettebuyer6369
I assume that while the custom one is only widened, its still a clean finished part, that they had to make (produce) as opposed to cutting a stock one. On top of that, they will sell far less of the custom ones than the correct stock ones, making them even more expensive to produce.
If the difference in price is so much and its an easy customization, then just buy a stock one and cut it up.
Old Apr 21, 2013 | 09:57 AM
mad pad house's Avatar
mad pad house
My bezel had already had some cutting on it by the previos owner.Delt with a Future Shop installer that ordered me a cover that fit into the stereo area of the bezel.Did the job well looks finished.Cost about $25.00.
Old Apr 21, 2013 | 10:12 AM
Stingray-Jer's Avatar
Stingray-Jer
I just checked the prices for 68 replacement bezels on Willcox. Here is what I found.
Both the early and late model 68 bezel goes for $310.00 http://willcoxcorvette.com/product_i...oducts_id=1243
The 69-71 bezel goes for $92. http://willcoxcorvette.com/product_i...oducts_id=1447
These are stock replacements. Not modified.
Old Apr 21, 2013 | 10:55 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Use the stock GM stereo and you won't have to fret over aftermarket prices. The precut bezels allow you to mount a DIN sized aftermarket stereo without having to cut your original bezel.
Old Apr 21, 2013 | 11:32 AM
Alan 71's Avatar
Alan 71
Hi m,
I guess the modified bezel's price is taking advantage of the fact that SOME people who want to change their radio don't have either the tool needed, or the skill required, (or both), to modify their existing bezel.
Regards,
Alan
Old Apr 21, 2013 | 11:59 AM
my 76 ray's Avatar
my 76 ray
Terry
Yes, that comes with a stereo but it doesn't have a CD. If you want a CD it's another $160 on top of that.
http://www.ecklerscorvette.com/corve...Product_Upsell
Old Apr 21, 2013 | 01:34 PM
Duane4238's Avatar
Duane4238
All this fuss about stereos and cd's. All my cars before my '72 had AM radios and we all made it through life!
Duane
Old Apr 21, 2013 | 04:48 PM
80Baby's Avatar
80Baby
I briefly considered a CD player. But the way I see it, CD's in cars will go the way of 8 Tracks and cassettes non too soon. Digital music on flash drives or iPods will be in vogue for some time to come. I opted to go with a standard bezel and retro looking radio with an Aux plug-in for my music.
Old Apr 21, 2013 | 06:46 PM
Stingray-Jer
Which one did you go with??
Old Apr 21, 2013 | 07:42 PM
loup68's Avatar
loup68
Army
Stingray-Jer, The reason that the 68 bezel is more is because they have to sand off the pebble finish bumps that GM put on the bezels in 69. I have never had glare from my gauge bezel or shifter bezel and will never understand why GM changed them. Lou.
Old Apr 21, 2013 | 07:57 PM
mds3013's Avatar
mds3013
For the plastic bezel cars I can help with the cutting. On the metal bezel cars, I will leave that to the old guys. mike...
http://forums.corvetteforum.com/c3-g...o-upgrade.html
To C3 Bezel Pricing ?
Old Apr 21, 2013 | 09:54 PM
fleming23's Avatar
fleming23
2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
For what it is worth, I purchased my "custom" 71 bezel from one of the forum vendors (not Willcox) and was sorely disappointed when it arrived. The "custom" bezel was nothing more than a cut up original (or reproduction more likely) with a dash plate put over top. The one I received still had a small amount of the text from the two shafts hidden behind the plastic DIN plate. I wish someone would make one that is all metal and actually a custom bezel!
Old Apr 21, 2013 | 09:59 PM
rcread's Avatar
rcread
That one would probably be about $600.
Old Apr 22, 2013 | 12:55 AM
Mashman's Avatar
Mashman
I bought a used bezel off eBay, and used a dremel to cut out excess material. It took a little while, but worked fine. Also, you can purchase a plastic piece that covers the sides of the raised portion of the bezel and makes it look good. I don't have the name of that plastic part but it's been mentioned on the forum multiple times.
