How much chrome on a base 350?
Old May 9, 2013 | 11:55 AM
MrT7's Avatar
MrT7
5th Gear
Default How much chrome on a base 350?
Just aquired a 72 that has the base 350 engine in it. The air cleaner lid, water pump pulley and alternator adjustment arm are chrome. Did the car origionally come with these chrome parts or should they be painted parts?
Old May 9, 2013 | 12:57 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by MrT7
...Did the car origionally come with these chrome parts..
If memory serves, the L-48 had a chrome air cleaner lid and snorkel can.
The brackets would have been painted.
Old May 9, 2013 | 01:21 PM
MrT7's Avatar
MrT7
5th Gear
Would the water pump pulley be painted also?
Old May 9, 2013 | 01:26 PM
Easy Mike's Avatar
Easy Mike
Yes.
Old May 9, 2013 | 01:27 PM
CoolShark's Avatar
CoolShark
Pulley would be painted.
Old May 9, 2013 | 01:33 PM
Alan 71's Avatar
Alan 71
Hi Mike,
I'll bite.... what's a "snorkel can"?
Regards,
Alan
Old May 9, 2013 | 01:35 PM
MrT7's Avatar
MrT7
5th Gear
Old May 9, 2013 | 01:38 PM
Sully1882's Avatar
Sully1882
air cleaner lid is only thing that is chrome from the factory, air cleaner base is dual snorkel type and painted flat black.
Sully
Old May 9, 2013 | 02:19 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by Alan 71
...what's a "snorkel can"?...
This one might be 71.
Old May 9, 2013 | 03:28 PM
MrT7's Avatar
MrT7
5th Gear
Thanks for the pic. Mine looks nowhere near that.
Old May 9, 2013 | 04:10 PM
Alan 71's Avatar
Alan 71
Hi,
Oh, the base.
I think it was painted SEMI-flat black.
With very little coverage on the bottom or the inside.
Regards,
Alan
Old May 9, 2013 | 04:16 PM
gbvette62's Avatar
gbvette62
Your 72 should look similar, to the car pictured, or at least it would have when new.
The only underhood factory chrome, on an L-48, was the air cleaner lid and the ignition shielding. The wiper vacuum can, on the car in the picture, should be gold cad, just like the master cylinder lid. The air cleaner base and the pulleys, were painted gloss or semi-gloss black.
Old May 9, 2013 | 04:32 PM
TheDucci's Avatar
TheDucci
Picture of your current set up would help to determine what should and should not be there.
Old May 9, 2013 | 08:13 PM
7T1vette's Avatar
7T1vette
Actually, the engine "components" were painted a semi-gloss black. The firewall and inner fenders were given the 'blackout' treatment with semi-flat black paint.
The only chrome stuff on the L-48 engine were the air cleaner lid and the ignition shielding (including spark plug shields and "V" wire shielding on the block). Everything else was painted Chevy engine orange, some type of black, or left as bare metal.
Old May 10, 2013 | 11:31 AM
MrT7's Avatar
MrT7
5th Gear
Mine does looks similar- but it has been sitting for over 20 years and will need a lot of work to look as good as the engine in the pic.
To How much chrome on a base 350?
