Headlight Problem - won't aim high enough
Now the previous lights were all set, so I was surprised to find alignment all off. The left headlight is low and to the right. The right headlight is left of center and low. Let's save I am comfortable about 40 mph max in the dark at where they are set, so you get an idea of how low.
Both high beams are low, but the left I could adjust up and left slightly to get about the right spot. The right high beam seems to now come up.
I can see the screws adjusting, but the high beams seem to be at their limits and not really high enough.
It almost is like the plastic/nylon adjuster stems are stretching or something, as I can see the screws adjust into them, but the lights don't really seem to move.
I'm also puzzled why they were so far off.
The headlight units themselves were not removed from the car or readjusted, so they are where they were.
Could the Sylvania lights be really wrong in where they are focused?
Anyone run into anything like this?
If you look at the back of each bulb you’ll see bumps that help align it in the correct position in the cup. If you don’t have these in the bumps in the grooves on the cups the lamps will be all over the place.
IMHO,
Willcox
Problem 2: If you remove the headlight capsule assembly...and watch out of the spring that aids in holding it in place. I have encountered NUMEROUS Corvettes over the years whose headlight bucket(s) were dented where it contacts the adjusters. These dents can effect headlight adjustment greatly.
Problem 3: Suspension is not correct and the front end is sagging below acceptable limits.
DUB
IMHO,
Willcox
Have bought a lot of parts from you for my 69 over the past 4 years and it still is not quite there. Please excuse the ignorance, but are you indicating that these "bumps" will automatically align the headlights?
I have one shooting up in the sky and one shining the road right in front of the car. I was looking for the, what I call typical, adjusting screws around the bezel.
