Interior light door switch
Old May 13, 2013 | 06:55 PM
moo2's Avatar
moo2
Default Interior light door switch
What is the black wire for on the drivers side interior light switch? The white one is hot and when I ground it the light comes on. Someone cut the black wire and I'm not sure why. I have a 69
Old May 13, 2013 | 07:50 PM
Mooser's Avatar
Mooser
I believe it's for the key warning buzzer that tells you you left the key in when opening the door
HIH
Mooser
Old May 14, 2013 | 07:03 AM
Alan 71's Avatar
Alan 71
Hi Moo,
I believe Mooser is right! Key warning buzzer.
Regards,
Alan
Old May 14, 2013 | 07:34 AM
Roco71's Avatar
Roco71
I disconnected mine.
Old May 14, 2013 | 09:20 AM
moo2's Avatar
moo2
Where is the buzzer at?
Old May 14, 2013 | 11:08 AM
Mashman's Avatar
Mashman
I have a 72, and it sits behind the drivers side dash, on top of, and between the speedo, and tach.
Old May 14, 2013 | 01:13 PM
Crafty12's Avatar
Crafty12
I believe it moved at some point in time. On my 70 the buzzer is in the horn relay. On my 73 it is between the tach and speedo as stated above.
Old May 14, 2013 | 09:41 PM
moo2's Avatar
moo2
It is in with the horn relay. Even that works now. Thanks guys
To Interior light door switch
