Thermostat dump
Old May 27, 2013 | 12:02 AM
Skip Burney's Avatar
Skip Burney
Default Thermostat dump
I have a Dewitts radiator with electric fans and I am thinking about getting rid of my water neck thermostat since there is a sending unit in the radiator to turn the fans off and on. I know all about how the thermostat is supposed to slow down the water and all but I have had cars without them before and didn`t have any problems. Just wondering?
Old May 27, 2013 | 12:42 AM
Shark Racer's Avatar
Shark Racer
The thermostat is NOT there to control the fans. It's to help the engine warm up. You actually need the engine to warm up a bit to get peak performance.
I run a 180* thermostat in mine. 195* thermostats are used in a lot of modern OEM applications to try to keep temps just hot enough to help with emissions. Some go down to 160* for better performance, but a little bit of extra warmth is good to help burn off some of the nasty stuff that builds up in the crankcase.
Old May 27, 2013 | 02:05 AM
Skip Burney
I know all about the intended purpose of the old bimetallc thermostats warming the car up a little quicker but by the time I get to the end of my driveway my car is already at 160. There was some discussion about it slowing the water flow down through the engine to allow the water to pick up more latent heat to be dissipated in the radiator but once the engine is thoroughly heat soaked that argument doesn't hold true either. My concern is that by leaving the old pill type thermostat in the water neck that is just one more thing to possibly fail and if it were to stick closed somewhere as has happened to me with one of my other Vettes then all of the money I have just invested in a radiator and fans would be useless.
Old May 27, 2013 | 02:29 AM
Bagmup's Avatar
Bagmup
Thing is though, without a thermostat, your coolant may not get hot enough for you big expensive fans to come on.
Whoever told you that doesn't have a clue.
But i suppose, what would all the car makers of the world know by spending billions trying to keep their engines at optimum temperature.
Old May 27, 2013 | 02:38 AM
Shark Racer
You must have a really long driveway. It takes me an easy 10 minutes to hit 160 in either of my 'vettes.
Old May 27, 2013 | 03:33 AM
Skip Burney
about 1/2 mile
Old May 27, 2013 | 08:19 AM
diehrd's Avatar
diehrd
A constant flow of water will transfer more heat then water sitting still and as long as you have enough surface area and air flow you potentially will cool better with out a thermostat , but air flow and surface area are critical factors and are limited under the hood of an automobile .
The reason you have temp controls on a motor it so you can reach and maintain operating temps within the confined spaces of an engine compartment. Having 100% flow does not allow you this option , it will be affected by so many factors that your motor will be cold as heck some times and to warm at other times.
I would not remove the thermostat , I also would not run a 160 in a motor with a carb.. Use a 180 buy a quality one and leave it alone.
Old May 27, 2013 | 08:29 AM
Arkyvette's Avatar
Arkyvette
Why not just buy a failsafe thermostat designed to fail in the open condition....
Old May 27, 2013 | 08:35 AM
imariver's Avatar
imariver
Aren't all t-stats failsafe open anyway? I had a t-stat go bad not too long ago and it (was) opened, it wasn't stuck, . . . it was just in the open position.
Old May 27, 2013 | 08:41 AM
Arkyvette's Avatar
Arkyvette
Not exactly..i have had a few fail and one of them was shut, truck warmed up really fast and didn't stop. Most are some degree of in between when they go out. The failsafe is supposed to mechanically lock open when failed. I've never used one btw, just sounded like it might be the peace of mind skip is looking for. As for me, I just keep an eye on the gauge.
Old May 27, 2013 | 10:04 AM
bpassmore's Avatar
bpassmore
One of the purposes of the thermostat is to maintain a uniform temp in the engine. If you don't want a T- stat you could use a restriction like the ones used in some race cars, but you have to figure the size so it takes time and a WAG to get them right.
With out the temp regulator (Thermostat) the engine coolant would be warmer or cooler in different locations in the engine causing "hot" and "cold" spots within the motor.
Old May 27, 2013 | 12:29 PM
7T1vette's Avatar
7T1vette
Just remove the thermostat. I'm not sure what you think the benefit of doing that will be, but you will get the side-effect of early engine wear and sluggish engine operation for the first 10 minutes or so.
Other than that...and no heater performance for several minutes in cold weather...you will cause no significant problems by removing the T-stat.
Old May 27, 2013 | 02:30 PM
oldschoolvette's Avatar
oldschoolvette
In addition there is the side benefit of the engine oil not heating up and driving the moisture out, this will make the oil go acidic and that is the cause (one of them) of the above quoted early engine wear.
if the engine does not get hot and reach an isothermal (all core temps the same) condition it will not last like it should
just buy the failsafe thermostat and be done
your engine will thank you
Old May 27, 2013 | 03:25 PM
Skip Burney
That's it exactly Arkyvette I was just looking for a little peace of mind, thanks for the advice, I figured that since the fans would hold the engine at 190 I could get rid of the thermostat or maybe just use a restrictor orifice. Like you I have had one stick shut also. At 62 years old I figure you can always learn from others and I have run cars without them with no problem. I also have 3 tractors here on the farm that run just fine without a thermostat OR a water pump but they are just old antique show tractors. On my Lycoming 180 hp airplane engine I have whats called a vernatherm to keep the oil temp in range and it is just like the car thermostats and it is designed to fail in the open position.
Old May 27, 2013 | 03:46 PM
mds3013's Avatar
mds3013
There are problems reported with the newer Mr. Gasket thermostats. They are a Robertshaw design that is supposed to fail in the open position. I am currently running them in a '69 429 LTD, a '71 429SCJ Mustang and my '77. So far no problems. I get them at Auto Zone in the engine dress up section. I will leave the decision to run without one to you. mike...
Old May 27, 2013 | 04:19 PM
Skip Burney
I have a new one sitting here on the shelf, I was going to use it in my 327 El Camino but I might give it a try in the Vette.
Old May 27, 2013 | 09:19 PM
Jeff_Keryk's Avatar
Jeff_Keryk
I am not sure why someone would remove a good thermostat.
If an engine did not need one, why did hundreds of millions of cars come with one?
Gotta be something there... Ya think?
To Thermostat dump
Old May 28, 2013 | 08:35 AM
77C34SPD's Avatar
77C34SPD
Unless your useing your corvette as a winter car, you can do this and never have a problem. Car will warm up with in ten minutes and will not overheat... Name:  Picture 315.jpg
Old May 28, 2013 | 10:06 AM
Skip Burney
Originally Posted by 77C34SPD
Unless your useing your corvette as a winter car, you can do this and never have a problem. Car will warm up with in ten minutes and will not overheat... Attachment 47726145
That's exactly what I am going with, I was going to machine a restrictor orifice to go under the neck but I have an old thermostat I will run it through the glass beader take out the pill and use it. There is never much winter here in south Georgia and I all I drive it for is fun so if it gets cold I will drive something else
Old May 28, 2013 | 10:09 AM
Mike Ward's Avatar
Mike Ward
Never underestimate the power of the age old belief that one person sitting under a shade tree can single handedly out-engineer GM and all other manufactures combined.
It starts with thinking 'stupid OEMs' and goes downhill from there.
It amazes me how long these cars last despite what people do to them.
