Coilovers
Old Jun 3, 2013 | 11:27 AM
The Punisher's Avatar
The Punisher
Default Coilovers
I see that corvette central sells a pair of front coilovers for about a 1k. They offer different spring rates. Has anyone installed them and what's the preferred spring rate. Thanks
Old Jun 3, 2013 | 02:32 PM
oldalaskaman's Avatar
oldalaskaman
prefered spring rate depends what you plan on doing with the car, weekend cruiser? stock, weekend warrior? stiff. your age comes into it also. I wanted it lower with close to the stock rate, so I cut one full coil off the stock front spring. it matches the rear and doesnt beat me up. made it easy to reinstall after rebuilding my front susp. also
hope this helps
Old Jun 3, 2013 | 08:50 PM
The Punisher
hope this helps
To Coilovers
