Front Suspension/Alignment Questions
Old Jun 4, 2013 | 12:41 AM
Dboy23's Avatar
Dboy23
Default Front Suspension/Alignment Questions
My 75' pulls to the left quite a bit so I'm pretty sure I need an alignment, the problem is I would imagine I would have to have newer front suspension (I'm not sure when anything was replaced). I was kinda looking for a starting point in going through the suspension to see what it might need before I could do an alignment, thanks in advanced.
Old Jun 4, 2013 | 02:20 AM
oldalaskaman's Avatar
oldalaskaman
look at the rubber bushings, i they are cracked and falling apart, you need a rebuild
Old Jun 4, 2013 | 02:31 AM
jesse10886's Avatar
jesse10886
well the front end is cheap to replace you can get a front end rebuild kit for around $300.
$279 for the all ball joints tire rods and bushings
http://www.ecklerscorvette.com/corve...1963-1982.html
if you are doing the work yourself this is your best bet then go get the car aligned with confidence that your front end is new.
I would jack the left front up first though an spin the tire. then the rear checking both for bearing wear and brakes sticking. it could just be a brake caliper sticking am you don't need an alignment.
Old Jun 4, 2013 | 07:57 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You may not have to do anything...yet. Take the car to the alignment shop and have it aligned. If parts are needed, the alignment tech can tell you what you might need.
Old Jun 4, 2013 | 09:35 AM
AirborneSilva's Avatar
AirborneSilva
Let the shop tell you that you need to replace the parts, mine did and didn't charge me a dime (or penny for that matter ).
Wilcox sells a complete front rebuild kit with Moog and Federal Mogul parts for about 250.... Just did mine and am very happy with it, the alignment shop said it was a first rate job
Old Jun 4, 2013 | 11:50 PM
Dboy23's Avatar
Dboy23
Thanks for all the info guys, I'm gonna see if I can find a shop near me that works on these things, thanks!
Old Jun 5, 2013 | 07:24 AM
AirborneSilva
Where do you live? Maybe a fellow forum member can suggest a shop.
To Front Suspension/Alignment Questions
