Am I a Bubba
Old Jun 9, 2013 | 07:38 PM
gr8t73's Avatar
gr8t73
Default Am I a Bubba
OK so after many failed attempts to install the correct wiring terminals for the hood alarm switch on my 73 I finally gave up and purchased an alarm switch for a 75 with the spade connectors. Works great just isn't correct. Has anyone figured out how to successfully install those flimsy terminals for the 73 switch.
Old Jun 9, 2013 | 07:53 PM
Arkyvette's Avatar
Arkyvette
Only if you twisted the wires and covered with electrical tape....
Old Jun 9, 2013 | 08:04 PM
Mooser's Avatar
Mooser
I didn't see any mention of using a doorbell button so I call no foul
Old Jun 9, 2013 | 08:10 PM
kdf1986's Avatar
kdf1986
I think Bubba would have used duct tape.
kdf
Old Jun 9, 2013 | 08:49 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
If you have to ask........
Having said this, I have no idea of how to connect the lead to those switches. After I split the switch in half, I covered the lead in shrink tubing. No alarm anyways. Yes I too am Bubba.
Old Jun 9, 2013 | 09:18 PM
69vette19467's Avatar
69vette19467
If you want an OEM crimp, get yourself one of these.
http://www.ebay.com/itm/Open-Barrel-Terminal-Crimping-Tool-OEM-Terminals-/370624944041?hash=item564af7d7a9&item=370624944041&pt=Race_Car_Parts&vxp=mtr#ht_2009wt_1015
I think I used barrel D for the wire and E for the insulation. Did a nice job.
Old Jun 9, 2013 | 09:35 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Bubba would have used old chewing gum and saved the wrappers to make cigarettes.
BTW, the aforementioned crimping tool is the correct answer.
Old Jun 9, 2013 | 10:51 PM
7T1vette's Avatar
7T1vette
Using electrical tape for an electrical problem????
You're not even in the same "league" with Bubba....
Old Jun 9, 2013 | 11:03 PM
scottyp99's Avatar
scottyp99
There are some people who think that if you use the wrong color bolt for something, you're Bubba, but it's not true. Bubba is a backward, barefoot, inbred hillbilly who is married to his first cousin, and has a relative that he calls "Uncle granpa!". He thinks that if you can't fix it with a hammer, it's an electrical problem. He "fixes" broken parts by removing them and throwing them away. If he ever gets access to a welder, and somehow gets electricity out to his shack, we'll all be in a lot of trouble! So, no, you are not a Bubba.
Scott
Old Jun 10, 2013 | 01:51 AM
oldalaskaman's Avatar
oldalaskaman
I quit using duct tape when they came out with gorilla tape, now thats an amazingly sticky, good holding, multi tool..and you can get it in camo and 8 other colors
Old Jun 10, 2013 | 05:51 AM
oldschoolvette's Avatar
oldschoolvette
to the OP I don't see the bubba connection
Old Jun 10, 2013 | 08:36 AM
Commodore's Avatar
Commodore
Most NCRS members (I'm one ) or certified NCRS judges (I am not one) where they to judge your '73 Corvette would go nuts for that terribly wrong '75 switch (the end must be near ). That horrible substitution will cost you lots of points - but you ain't no buba. Buba would have used a string attached to his wife's alligator that she keeps under Buba's hood. Buba would have skipped the switch completely because Buba's Corvette doesn't even run. It's engine is [mostly] in his truck now.
Sounds like I just wrote an episode for one of those reality shows!
RB
Old Jun 10, 2013 | 09:08 AM
Arkyvette's Avatar
Arkyvette
Yes, but all tape is lectric tape to bubba. Scotch....double sided.....duck.....masking tape....it don't matter
Old Jun 10, 2013 | 12:54 PM
Denpo's Avatar
Denpo
Bubba would never wonder if he is what he is.
He's cocksure he isn't.
So you're safe.
Old Jun 11, 2013 | 10:16 AM
71scgc's Avatar
71scgc
At some point, we are all Bubbas.
Carter
Old Jun 11, 2013 | 11:17 AM
gr8t73's Avatar
gr8t73
I knew I would get some great replies and a few good laughs when I posted this. Thanks gusy.
Old Jun 11, 2013 | 11:19 AM
gr8t73's Avatar
gr8t73
I knew I would get some great replies and a few good laughs when I posted this. Thanks guys.
To Am I a Bubba
