1973 with A/C
Old Jun 10, 2013 | 07:13 PM
Delta26's Avatar
Delta26
Default 1973 with A/C
I am looking for a 72 or 73 coupe. I live in Florida so A/C is a must. Why is it that 95% of the Vettes I see with A/C - it doesn't work or is out of the car all together? Thanks.
Old Jun 10, 2013 | 07:15 PM
imariver's Avatar
imariver
It really raises hell with my sinuses.
Old Jun 10, 2013 | 07:32 PM
redwingvette's Avatar
redwingvette
The 73 system did not work all that well even when new so the cost to repair it is not all that. If you do find one then it is not that difficult to upgrade/replace with new technology stuff.
my page
Old Jun 11, 2013 | 09:03 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Delta26
...Why is it that 95% of the Vettes I see with A/C - it doesn't work or is out of the car all together?...
Fate?
Bad Karma?
Some one up there doesn't like you?
Old Jun 11, 2013 | 04:06 PM
DC3's Avatar
DC3
If you can't find a car with a good working AC, you might be better off finding a non-AC car and adding Vintage Air. That's the route I ended up going and I'm pleased with the VA system. A bit of a PITA to install but in the end, it's modern technology and it gets cold.
DC
Old Jun 11, 2013 | 08:56 PM
Delta26's Avatar
Delta26
Thanks redwingvette and DC3 for the feedback. your replies shed some light on the situation.
I was hoping to get more replies like yours. I never thought of the VA system. Now, I'll check it out. I've passed up a lot of potential '73's for lack of AC. Thanks, again.
Old Jun 11, 2013 | 09:52 PM
DC3's Avatar
DC3
I passed up a couple of good cars too until I decided VA was a good option.
One thing to know about the VA system is that it is a recirculating system only (does not bring in fresh air). That may or may not be a big deal to some. It wasn't a problem with my '73. As a non-AC car, it had the Astro Ventilation system with the fresh air vents at the kick panels and in the dash. You have to block the ones for the dash but I left the kick panel vents in place. If the VA system gets too cold on moderate days, I can temper it by opening the kick panel vents. Or, if it's not really AC weather and I just want a bit fresh air they are handy to have.
DC
Old Jun 11, 2013 | 11:06 PM
ClassicGlass63's Avatar
ClassicGlass63
Default A/c
The A/c systems are very easy in these cars. It is almost a must to have it to enjoy a long ride in these things. Especially with a big block.
If you are going to fix up one of these cars, buy one with air in it. It does not matter if it works or not.
I have helped over thirty guys get their working.
I hate to admit that I added Vintage air to a car. It was a 63 though were virtually none of them had it.
I too live in a warm state. California. Driving the 63 without A/C was miserable.
Old Jun 12, 2013 | 01:42 AM
7T1vette's Avatar
7T1vette
The A/C systems in NEW C3's worked just fine. In fact, that small cockpit was no match for the full-sized car A/C system in the Corvette. Not sure why some folks think it didn't work that well....I've had a new '74, a 5 year old '68, and my present '71. The new car A/C was fantastic; no problems with the '68s A/C. It took a while to solve all the "other" issues that were allowing heat to enter into the passenger area of the '71, but once that was done I had no problem getting cool in Phoenix, AZ for a few years.
Folks think that since the system is "old", it won't work well. They might not be as efficient as a newer system, but there has been no great improvement in A/C performance....only better electronic management of temperature, air distribution, etc.
Old Jun 12, 2013 | 07:07 AM
dtamustang's Avatar
dtamustang
I agree 100% with 7T1vette. original a/c works great in mine, even converted to 134.
vent temps are in the mid 40's. nothing wrong at all with a 40 year old system in proper working order
Old Jun 12, 2013 | 04:12 PM
LS4 PILOT's Avatar
LS4 PILOT
The AC in my first 74 Coupe ( my first vette)which was nearly a new car back in the 70's worked just fine . As did several other coupes I owned from the 70's
I shopped for a 74 convertible I own now 25 years ago , when I bought it , it just happened to have AC, and it has never worked .....its a fun in the sun car , top down nearly all year ....could care less about AC.
Old Jun 12, 2013 | 04:21 PM
keithinspace's Avatar
keithinspace
My A/C doesn't work either.
Then again, neither does my heater, my wipers, my wiper door, my clock...
And, to be fair, the A/C went out in my 2005 Expedition...leak...
I think folks take them out because they weigh so much. The compressor alone is an easy 40 lbs. I just put aluminum heads on my car, in part, to save weight. So if I was nuts about it, I'd be a little silly to NOT pull the A/C system. The whole thing probably costs an easy 100 lbs, if not more.
I'd love to get mine working, and have every intention to. Neet to start by getting the engine back in the car...
Old Jun 13, 2013 | 12:31 PM
The Spark's Avatar
The Spark
I replaced all the components in my 72 ac system.
Fortunately it came with ac from the factory. Replaced the hoses, drier, compressor, POA valve from the catalog businesses. Had to replace one component from a business that specializes in antique auto ac systems.
I know very little about a/c systems but I did all the work myself.
I bought a vacuum pump from Harbor Freight to put vacuum on the system and used a/c gauges from Harbor Freight to put in freon.
System works good.
Old Jun 13, 2013 | 12:45 PM
budco's Avatar
budco
There's not much difference in a/c systems in the last 40 years. The only thing they improved on is the compressor, and that is debatable. The newer compressors use less hp to run them, don't work a whole lot better. I've been working on trucks with a/c for over 35 years and I'd rather have an older system anytime. Start replacing parts with climate control and you'll see what expensive is.....
Old Jun 13, 2013 | 12:54 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by 7T1vette
...The A/C systems in NEW C3's worked just fine...
They continue to work just fine if they are maintained.
To 1973 with A/C
