Oil Pressure
Old Jul 1, 2013 | 10:29 PM
gpvett79's Avatar
gpvett79
Default Oil Pressure
My 79 vette 350 engine I put a new oil pressure pump on it now the pressure is like 80 psi is to much pressure on the oil is this bad for the engine and seals should I try to get the oil pressure back down thanks
Old Jul 1, 2013 | 10:46 PM
bashcraft's Avatar
bashcraft
What weight oil are you using?
Old Jul 1, 2013 | 10:47 PM
gcusmano74's Avatar
gcusmano74
80 psi hot on a smallblock is kind of a lot. For a street car, all you really need is 60 to 65 psi, tops. Rule of thumb on a SBC is that 10 psi engine oil pressure per thousand RPM is safe. Any more than that most likely just heats up the oil and takes a bit more power to drive (the pump).
Please correct me if I am wrong. Pressurized oil doesn't get to the front and rear main (crankshaft) seals. They are splash lubed only. The seal on the oil filter is the only one that sees full pump pressure.
Old Jul 1, 2013 | 10:53 PM
gpvett79's Avatar
gpvett79
I am using 10 w 40 weight
Old Jul 1, 2013 | 11:06 PM
BBCorv70's Avatar
BBCorv70
Sounds like you have a high volume pump installed. There's another thread on this topic, posted a few days ago. I don't think it does much harm nor do I think it does much good either. The high pressure may increase oil consumption a bit. Some have stated the high volume pumps tend to pump most oil to the top of the engine at high RPM.
I have a high volume pump in my 70 big block, the pressure stays high even when the engine is fully warmed. I do notice a bit more oil consumption than expected. If it wasn't such a project removing the pan and pump I'd consider going back to a stock pump.
Your call.
Old Jul 2, 2013 | 02:17 AM
oldalaskaman's Avatar
oldalaskaman
it will drop off to bout 70 at idle cold and 45 idle hot. till it does, if it worries you you can change the oil to a lighter weight, which should lower the pressure ...a bit
Old Jul 2, 2013 | 07:10 AM
bashcraft's Avatar
bashcraft
Try 10w 30, or even 5w 30.
Why do people think that they need to run heavy oil?
Old Jul 2, 2013 | 12:23 PM
74Ken's Avatar
74Ken
I have the same problem. My gauge says 80 PSI. Was freaking me out at first. Since the car is new to me, I watch the gauges all the time.
I was leaking oil out of the dip stick tube, I thought maybe it was related to the pressure being so high.
Old Jul 2, 2013 | 02:18 PM
zwede's Avatar
zwede
Nope, oil pressure doesn't cause that. Cylinder blow-by (bad piston rings) does.
Old Jul 2, 2013 | 04:03 PM
7T1vette's Avatar
7T1vette
...or non-functional (or non-existent) PCV system. The PCV system sucks the internal engine vapors [and pressure] into the intake charge. No PCV system? No pressure vent, unless you have a dedicated breather on a rocker cover.
Old Jul 3, 2013 | 12:18 AM
74Ken's Avatar
74Ken
Actually I have both, PCV and dedicated vent on the valve cover.
It came that way.
I'm betting old rings, might just have to have the engine rebuilt over the next few years...hmmm, sorry honey, I gotta do it, lol
Mechanic told me to pull the tube out, put some silicon on it and stuff it back in for now.
Old Jul 3, 2013 | 06:59 AM
oldalaskaman
It came that way.
you have a breather, you have a pvc, you have oil pressuring out the dipstick tube, and your mechanic told you to plug it with silicon...for now.
......allrighty then
Old Jul 3, 2013 | 07:28 AM
74Ken's Avatar
74Ken
oldalaskaman, can you explain the sarcasm please...to us non-mechanic folks.
Are you saying I should not have a PVC and a breather in the first place?
I understand that adding silicon will not 'solve' the problem, but I was hoping it would stop the dripping of oil on my garage floor until I can find a more permanent solution. He suggested it because the tube is lose and that's where the oil was coming from.
Old Jul 3, 2013 | 11:14 AM
7T1vette's Avatar
7T1vette
If the oil is leaking from the joint between the engine block and [the bottom end of] the dipstick tube, you just need to reseal that joint. But, don't use silicone sealant to do that; silicone does poorly at sealing oil related leaks. Remove the tube, clean the bottom of tube and mating bore in the engine block with lacquer thinner or other volatile cleaner, put some Permatex #2 gasket sealer on the tube and tap it in place. Let set overnight before you fire it up.
Old Jul 3, 2013 | 11:18 AM
74Ken's Avatar
74Ken
Perfect 7T1, thanks for the advice.
Old Jul 3, 2013 | 04:37 PM
oldalaskaman
that makes more sense, seemed as though you were gong to plug the tube , didnt mean sarcasm, just observing at 0400, I usually go back and delete but I fell asleep
Old Jul 4, 2013 | 12:10 AM
Skip Burney's Avatar
Skip Burney
Originally Posted by 7t1vette
if the oil is leaking from the joint between the engine block and [the bottom end of] the dipstick tube, you just need to reseal that joint. But, don't use silicone sealant to do that; silicone does poorly at sealing oil related leaks. Remove the tube, clean the bottom of tube and mating bore in the engine block with lacquer thinner or other volatile cleaner, put some permatex #2 gasket sealer on the tube and tap it in place. Let set overnight before you fire it up.
exactly
To Oil Pressure
