Body off 69 question
Old Jul 7, 2013 | 02:15 PM
Mikesfreetime's Avatar
Mikesfreetime
Default Body off 69 question
I seem to be missing something. I have all the body bolts and think everything else but there seems to be something around the front of the door area and behind front wheels sticking. I can lift from the back and from the front but the middle is hanging. Seat belts are out, the bolt at the front corners are out. HELP jog my mind....
Old Jul 7, 2013 | 02:18 PM
Alan 71's Avatar
Alan 71
Hi,
4 body bolts each side?
Regards,
Alan
Old Jul 7, 2013 | 02:33 PM
Mikesfreetime
Default bolts
Originally Posted by Alan 71
Hi,
Regards,
Alan
One at very rear, one in front of rear tire, one in front of door on the inside, and one under the front door behind front tire correct?
Old Jul 7, 2013 | 02:37 PM
stpman's Avatar
stpman
yep, do you have the cable for the seat belt bracket removed?
Old Jul 7, 2013 | 02:39 PM
Mikesfreetime
Default seat belt
Is that inside or under the car?
Old Jul 7, 2013 | 02:46 PM
Alan 71's Avatar
Alan 71
Hi,
It's under the car in the transmission tunnel.
Is the shifter hanging up on the inner shifter boot? Maybe the shifters not there? Are engine and transmission still in place?
A fuel line, vapor line, or brake line?
Speedometer cable?
Ground strap?
Regards,
Alan
Old Jul 7, 2013 | 02:53 PM
Mikesfreetime
Hi,
Speedometer cable?
Ground strap?
Regards,
Alan
Motor and tranny are in the car. Brake lines are unhooked, speedometer cable is off. Shifter is in place I will go check for the seat belt bracket. It something fairly solid because it wont seam to lift much at the front of the door.
Old Jul 7, 2013 | 03:02 PM
Mikesfreetime
Was not the belt strap, I had that removed...
Old Jul 7, 2013 | 06:04 PM
bwinterstine's Avatar
bwinterstine
My 75 had a ground strap just behind the driver side front wheel
Old Jul 7, 2013 | 08:25 PM
RobRace10's Avatar
RobRace10
Hi,
Regards,
Alan
The bolts behind the kick panels out?
There is one in front of the firewall, one behind the firewall ( behind the kick panel), one just behind the doors and the one on the rear kick up area.
Old Jul 8, 2013 | 09:31 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...I seem to be missing something...
Are you trying to do all this without an assembly instruction manual (AIM)?
Old Jul 8, 2013 | 01:44 PM
my 76 ray's Avatar
my 76 ray
How is an ASSEMBLY Instruction Manual going to help him. He's taking it apart. He need the TAIM (Take Apart Instruction Manual).
Old Jul 8, 2013 | 02:03 PM
427basketcase's Avatar
427basketcase
I don't suppose he could use those "Assembly" pages for reference could he?
Old Jul 8, 2013 | 02:12 PM
Alan 71's Avatar
Alan 71
Hi,
I agree, the Assembly Manual is EXTREMELY handy to refer to while doing the work required to remove a body from the frame.
Regards,
Alan
Old Jul 9, 2013 | 07:03 AM
Mikesfreetime
Hi,
Regards,
Alan
I do have and have been using an assembly manual but they really dont provide a step by step. I wish someone TOFTT and did a step by step from start to finish. Of course I just jumped in and starting tearing it apart the same day it hit my driveway. Anyway, tonights the moment of truth!
Old Jul 9, 2013 | 11:07 AM
MuskieAL's Avatar
MuskieAL
St. Jude Donor '15 thru'19,'23 thru '26
Hi Mikesfreetime
Not sure if it's to late. I found this info on Kevin McKay's web site. Maybe it will be of some help with your body lift.
http://corvetterepair.com/services/tech-tips/
AL
Old Jul 9, 2013 | 01:38 PM
Mikesfreetime
Originally Posted by MuskieAL
Hi Mikesfreetime
AL
Thats a sweet check list. Thanks
To Body off 69 question
