1969 Underbody Heat shield Brackets
Old Jul 11, 2013 | 10:15 PM
DAVID SLUDER's Avatar
DAVID SLUDER
Default 1969 Underbody Heat shield Brackets
Wondering if anybody might know what the correct color of these brackets are that hold the underbody shields in place, any pics would be greatly appreciated also, Thanks
Old Jul 11, 2013 | 10:28 PM
68/70Vette's Avatar
68/70Vette
I have these brackets on my 68. They were installed on 68 and 69's. I plan on installing them on my 70. I've already bought them from a Corvette vendor. The 68 and 69 had a lot more thermal protection that the 70 and later cars. I'll build my 70 with a 68/69 underbody thermal blanket system. I'm pretty sure they were painted black.
Do you have some reason to think they weren't painted black?
Old Jul 12, 2013 | 07:03 AM
DAVID SLUDER
I know the bottom metal floor pan heat shield is covered in a gray phosphate finish and the toe-pan on the firewall is off white, but no mention of the brackets which are riveted to the crossmember, im assuming they are chassis black
Old Jul 12, 2013 | 07:33 AM
Alan 71's Avatar
Alan 71
Hi David,
I believe the brackets for the heat shields were plated dark phosphate and not painted semi-flat black.
Perhaps someone with more 69 knowledge will add their thoughts.
Regards,
Alan
Old Jul 12, 2013 | 08:47 AM
exposingtime's Avatar
exposingtime
2015 C3 of the Year Finalist
Here are pics of the front and rear of my 69. I believe that they were painted black as all that I did was clean them. The white plastic deflectors and the metal heat shields were covered with 40 years worth of grease and road grime.
Gary
Old Jul 12, 2013 | 08:53 AM
exposingtime
Tried again. Something didnt look right
Old Jul 12, 2013 | 12:14 PM
steffan's Avatar
steffan
mine are black.one shield and one bracket was missing from my car when I bought it.The replacement shield and bracket came in black too.
Old Jul 12, 2013 | 02:53 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Gary, those appear to be black phosphate to me. Have you checked the TIM&JG?
Old Jul 12, 2013 | 03:22 PM
Alan 71's Avatar
Alan 71
Hi Gary,
I'm wondering how original the finish on the brackets in your picture may be since it appears they've been off the car. The pop rivets used to re-install them is the give-away.
Regards,
Alan
Old Jul 12, 2013 | 04:22 PM
steffan's Avatar
steffan
left original or on car when I bought it, right is replica
Old Jul 12, 2013 | 06:09 PM
DAVID SLUDER
Thanks so much guys, just what I was looking for, I knew yall would come through, the pictures are great, thanks again David
To 1969 Underbody Heat shield Brackets
