Definitley powder coat. I did mine 16 years ago and it still looks fine. No peeling or rust etc. There are many different shades of black to get the exact color you want.
It's been extremely durable. If it peels off..it had poor preparation. It absolutely has to be rust free, clean and dry before coating. They *dusted* mine by sandblasting it immedately before coating to make sure there was no surface/flash rust anywhere.
I also "acid dipped" my frame and powdercoat was sprayed inside the rails also.
JIM
I went with POR 15 and I am extremely happy with the results! I don't have any pics but I would recommend the product! It was perfect for my 73 rest-mod project and helped me keep costs in line without sacrificing quality.
Looks like we all have a lot of different anecdotes. I had a lot of sheet metal interior parts/radiator frame, etc powder coated on my 68. $$$$$ I has later horrified to see some rust. Apparently the powdercoater left some pits in the paint (?) that later developed rust. I had to overpaint with rustoleum. I noticed Alan's response...powercoat it and then paint over it with the correct paint.. that pretty much covers the bases.
Some of my rear suspension parts that I ordered were powdercoated. They were chipped in shipping (VBP), rather than return them and go through the hassle, I just painted them over with POR15.
So what is the correct black for the frame and other parts such as radiator support?
I'm not a NCRS purist. However, my guess is that Eastwood's black chassis paint is pretty close. When you say you want a correct black, I think you mean that you want a black paint with the correct gloss. Gloss is the first consideration, and then the thickness of the paint. Some frame paints are very "thick." I use Eastwood's but I'm not a NCRS purist...(although I like to remain true to the original car as a guide).
Thats exactly what I mean, I want to be able to drive my car and not worry about every detail.
Hi mft,
I believe semi-flat black is the general description for the paint used on the chassis and of other painted parts of the era we're interested in.
Actual most people agree that the degree of gloss varied from part to part and often depended on how the part was painted. For instance the frame was quickly sprayed and may have less gloss than some small brackets that were dipped, and might have more paint on them, thus they MAY show a higher level of gloss.
So I guess a 'range' of gloss would be appropriate and that range can be obtained by how wet you make the coats of paint, and how far you hold the spray valve from the piece you're painting.
It's all fun!
Regards,
Alan
I went with paint 20 years ago. After driving once in a while over the last 3 or 4 years, I'm seeing erosion, some rust starting up again. If I were to do it over I'd opt for powder coating, assuming if there were any flaws where rust may start, they'd be much easier to deal with than doing the whole frame over. I'd look into which coating gives you the best long term, maintenance free life.
