Driving time v repair time
So the question is how much time to you spend driving you Vette compared to repairing it !!!
If you have major work to do, schedule it for time of year when you likely won't be driving it. AND...make repairs to "safety" related stuff first (steering, suspension, brakes, lights, etc.); "operational" stuff second, and "cosmetic/appearance" stuff LAST.
That way, when the safety related repairs are done and operational repairs allow the car to be driven, you can be using the car and have only incidental downtime periods to do other needed work.
You are being facetious
. Of course some of us drive. Drive to fix ratio about 5:1. Aside from some brake caliper work this spring things are going OK; all 650 miles worth so far.
Next, I noticed a death-rattle ping under even light acceleration, and since I was curious to find out if the car had 46,000 or 146,000 miles on it, I pulled the motor, had the pistons cut to drop the compression one point, got a slightly more aggressive cam, had the rotating assembly balanced, hard valve seats installed and put that all back together. After pulling the motor twice more (to correct a head- machining issue by my machine shop) I finally had THAT running right, and during the third go- round with the motor I decided I wanted a yellow Corvette, so I repainted it yellow.
A couple years later, after putting about 20,000 miles on it, I reupholstered the seats, and in 2006 I decided to swap out the TH400 automatic for an M21 4-speed.
Most recently, I submitted the car to a two-year strip and repaint, along with new carpet, and after replacing the shocks that came with the car 15 years ago along with one leaky brake caliper the car drives and actually handles better than I ever imagined it could.
I recently got sent to go work 140 miles from home, and since my employer was paying for the mileage to the tune of 56 cents a mile, I took the Vette, and never had a problem. In three weeks a friend and I will be driving it up to Laguna Seca for this year's Monterey Motorsports Reunion (where Corvette will be the featured marque), and honestly having the chance to drive a classic 60's-era Corvette up Pacific Coast Highway is the fulfillment of a dream, and worth all the sweat and busted knuckles.
IMHO, unless you're either rich enough to pay a competent mechanic or you are yourself a competent mechanic, you really should not embark on the adventure of owning one of these cars because it will very likely become an expensive and time-consuming exercise in frustration. If you are one of those things, the experience of getting one of these cars properly dialed in can be very rewarding indeed...
