Did this stripper go too far?
Old Jul 27, 2013 | 10:53 AM
jr73's Avatar
jr73
Default Did this stripper go too far?
I'll put up some pix but I bought my 73 with most of the paint stripped. The owner said he used a stripper designed for fiberglass but Im wondering if he went too far. Most of the car feels fuzzy and being a Corvette virgin im not sure how far is too far. A Vette guy I talked to said the guy may have taken off the Gel coat and to re-apply that will be a nightmare. Am I in trouble? Pix to come.
Old Jul 27, 2013 | 11:04 AM
Alan 71's Avatar
Alan 71
Hi jr73,
There wasn't any gel coat on the fiberglass surface of your 73. Boats and port-potties have gel coat on them.
If you're feeling 'fuzz', the person doing the stripping went too far. It wasn't necessarily the fault of the stripper being used.
Seeing some pictures will help people give you some suggestions how best to proceed.
Good Luck!
Regards,
Alan
Old Jul 27, 2013 | 11:09 AM
TWINRAY's Avatar
TWINRAY
Maybe it's paint/primer residue and needs to be sanded. Photos will determine that. While in the past I've used stripper, now I just "blade" the old stuff off now just to be safe.
Old Jul 27, 2013 | 12:54 PM
69FASTFUN's Avatar
69FASTFUN
How long has the car been stripped? If the car has been sitting say about a year and sunlight hits it the UV rays deteriorate the fiberglass resin leaving just the fibers. I have used resin and hardener and brushed it on and then block sand and comes out perfect.
Old Jul 27, 2013 | 01:39 PM
jr73's Avatar
jr73
the seller said he has had the car sitting in his garage for 20 years Im not sure how many of those years were spent stripped but I will ask him. That resin and hardener sounds better than the gel coat nightmare the Vette guy told me he did on his 66.
Old Jul 27, 2013 | 02:00 PM
Alan 71's Avatar
Alan 71
Hi jr73,
When using either resin or gel coat the WORK is in block sanding as 69F said.
The DIFFICULT part is getting all the edges back on the hood and doors. Then the TRICKY part is getting the sharp creases back on the fenders and the wheel openings.
Once you know what to look for you'll begin to notice bodies that have had the detail sanded off.
Careful!
Regards,
Alan
Old Jul 29, 2013 | 07:45 PM
jr73's Avatar
jr73
ok here are some pix, this is of the right fender, probably showing the most fiber
Old Jul 29, 2013 | 07:47 PM
jr73's Avatar
jr73
the same fender
Old Jul 29, 2013 | 07:48 PM
jr73's Avatar
jr73
about half the car is like this, not as fuzzy but enough to make me itchy
Old Jul 29, 2013 | 10:32 PM
Duane4238's Avatar
Duane4238
Where did all of your pics go? It says you deleted them!
Duane
Old Jul 29, 2013 | 11:37 PM
jr73's Avatar
jr73
Duane
what?
Im looking at them now
Old Jul 30, 2013 | 12:40 AM
orourke's Avatar
orourke
Nope, I don't see them. "Moved or deleted".
Old Jul 30, 2013 | 01:11 AM
jordan89's Avatar
jordan89
You probably deleted them from photobucket and that's why they're not showing.
Old Jul 30, 2013 | 07:19 AM
jr73's Avatar
jr73
I moved them to a new album maybe that did it.
I just redid the posts let me know if you guys can see them now.
Old Jul 30, 2013 | 08:32 AM
imariver's Avatar
imariver
At this time, I see them . . . .
Old Jul 30, 2013 | 08:53 AM
TexasYankee's Avatar
TexasYankee
I had the same question following the last Bachlor's party I attended...
Sorry, couldn't resist....
Old Jul 30, 2013 | 08:57 AM
zwede's Avatar
zwede
Looks like UV damage. I suggest you repost (with your pics) over in the paint & body section of the forum. I don't know if it will be enough to cover this with primer or if it would be better to gelcoat it?
To Did this stripper go too far?
Old Jul 30, 2013 | 09:46 AM
TWINRAY's Avatar
TWINRAY
Wow, I never saw anything like that. That couldn't be a totally repaired section with matte/resin could it?
Old Jul 30, 2013 | 01:01 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Is that a hole in the hood surround panel? I have a hunch the pink is bondo. Rear deck looks okay to me.
Old Jul 30, 2013 | 02:23 PM
markids77's Avatar
markids77
It looks to me that your car has had a replacement nose and in the process of making all the parts fit flush someone attacked that fender and top surround with a sanding board and 24 or 36 grit paper... and kept sanding until some areas are almost paper thin.
Short answer; yes you have trouble. If the whole nose is as thin as the area with the hole you cannot leave the parts this thin, they will not live in the open air and daylight. Reinforcing that large an area with fresh laminations is a herculean task... replacing it is probably the best cure.
Check any areas that look like your first photos carefully to see how thin they are and report back. I agree with easy mike that the rear of the car looks unmolested, simply no paint and years of dirt on top.
