Seat Belts
Old Aug 7, 2013 | 11:14 PM
VetteRock89's Avatar
VetteRock89
Default Seat Belts
What years of corvettes have the same seat belts? The date doesnt matter, i just want them to look the same so what years of c3 look the exact same? I have a 71
THanks
Old Aug 8, 2013 | 07:18 AM
7T1vette's Avatar
7T1vette
I think that the '70 car had the same belts as the '71. And those were not the same as any other year.
What are you trying to do? Do you need webbing? hardware?
Old Aug 8, 2013 | 08:37 AM
gbvette62's Avatar
gbvette62
70 and 71, all used the same belts.
69 was a split year, with the plastic buckle belts that were used at the beginning of the year, being replaced by what I think were the same belts as the 70-71's, later in the model year.
72-73 belts, are similar, but had retractors for the lap belts.
Old Aug 8, 2013 | 11:10 AM
VetteRock89
I. Recently picked up and driving project 71 and need seat belts in order to drive it! I want to know what to be on the lookout for! I just need a full set of seat belts lap and shoulder with everything. My car had nothing at all to do with belts
Old Aug 8, 2013 | 12:48 PM
7T1vette's Avatar
7T1vette
The '70/71 belt hardware is very difficult to come by. There are some repop sets that are very good; but they are also very expensive.
And, I must tell you, that the original belt sets have their own set of problems which you may not care to perpetuate. The lap belt and shoulder belt are separate items, with a 'rivet-type' post on the lap buckle to which the shoulder buckle mounts. PITA. More importantly, the shoulder belt retractors of that era DID NOT ratchet so that you could keep the belt from rubbing your neck raw. That improvement came later.
If I were in your position, I would get a decent set of belts from a later-model Camaro/Firebird. There should be several threads archived on what to buy and how to install them. They would be much easier for the passengers to use and more comfortable, as well.
If you want it to be NCRS-grade 'correct', you will just have to find all the right hardware for the '70/71 cars and have new webbing installed to it.
Old Aug 8, 2013 | 02:20 PM
palmbeachvette76's Avatar
palmbeachvette76
For your '71 if factory equipped would have come with two piece belt system consisting of a Non-retractable lap belt and a Retractable Shoulder belt. The shoulder goes through the seat so you'll need to look at your seats and see if you have the metal insert that runs the wide of the upper portion of the seat. Most seatbelt delete cars have this but the openings for the seatbelts are covered. You'll need a Left and a Right version of this with the openings. Chances are you'll also have to purchase the rear chrome openings and cut the seat material to install these.
You'll need to check the mounting hole location for the buckle side. 1969-1971 are normally 12" since the mounting hole was at the very back of the transmission tunnel. In 1972 the moved the hole forward and switched to a 7.5" buckle and sleeve then in 1974 the went to an 8.5". I have seen some 1970 and 1971 cars that have the shorter buckle and sleeve. The reproduction belts that my company builds come with the longer version but I have swapped several for cars that had either had theirs changed or came from GM with the shorter version.
The 1970-71 also used a horizontal mounting position for the shoulder retractor whereas the 1968Late and 1969 were mounted on a vertical plane on the rear wheelwell.
Old Aug 8, 2013 | 04:33 PM
BOSTONCAMARO's Avatar
BOSTONCAMARO
I know you know your stuff, someone on here told me that 69 was a 3 type of belt year...my car was built in Nov 69.I could not find any used belts and my buckle design seems to be a bit different than others...I was told there were 3 types
Here are mine, back from chroming
Old Aug 9, 2013 | 05:38 AM
palmbeachvette76
I know that there was 2 different buckles used. A plastic GM press button then the satin finish metal GM Mark of Excellence buckle came out late '69 and continued through the C4 cars before they switched to the plastic end release buckles that are currently used.
Your tongues came out great if you don't have buckles you'll have to find the correct GM metal buckles for those tongues since they changed internally. Outsides all look the same but the latch catch inside is a different depth so I hope you have the buckles that are matched to those new tongues.
Yours are also the one year that the shoulder belt has the post that inserts into the slot on your tongues. 1970 and up they switched it so the shoulder has a collar and the tongue had the post.
To Seat Belts
