Standards for measuring horsepower: 1969 427 compared to 1972 454?
Old 08-11-2013, 03:25 PM
Puman
Puman's Avatar
Default Standards for measuring horsepower: 1969 427 compared to 1972 454?
In 1972 454 cubic inch big block motor was rated at 270 hp.
In 1969 427 big block was rated at 390 hp.
http://web-cars.com/corvette/1972.php
From the link above, I found out that standards for measuring horsepower came into effect in 1972 and that's why the lower hp numbers.
Can any of you tell me how much horsepower the 1969 427 or 350 engines have by todays hp standards?
In 1969 427 was rated at 390 hp as mentioned above and 350 small block was rated at 350 hp. But measuring the hp by todays standards, those hp numbers are lower.
Old 08-11-2013, 05:01 PM
Faster Rat
Faster Rat's Avatar
Old 08-11-2013, 05:56 PM
whitehause
whitehause's Avatar
From my understanding, and put very simply....
The old way was called "Brake HP" and was measured directly from the motor on a stand.
The new way is called " Rear wheel HP" which is just what it sounds like. The HP measured at the rear wheels with all the HP robbing drive train components in the mix.
In reality the way they calculate HP numbers were probably changed to help with the new government regulations, even though for a couple years they were the same engine.
Old 08-11-2013, 06:30 PM
zwede
zwede's Avatar
Nope.
Old standard was SAE Gross. It was very lenient (unrealistic) as far as inlet air temp and humidity. It also allowed open headers, recurved distributor and running with no accessories.
New standard is SAE Net. Realistic air temp & humidity. Full exhaust as installed in vehicle including mufflers. Accessories such as water pump is hooked up. Distributor & carb/injection & air cleaner as installed in vehicle.
SAE Net is not rear wheel power.
1971 GM cars give you a real good idea of how the ratings compare as the engines were rated both ways. The '71 Corvette LS5 was 360 hp gross, 285 hp net.
Extrapolating a bit, the '69 427/390 would be ~310 net hp. The '72 454/270 would be ~340 gross hp. Something along those lines at least.
Old 08-11-2013, 06:48 PM
Mike Ward
Mike Ward's Avatar
Originally Posted by zwede
Nope.
both SAE Gross and Net are 'brake' horsepower- the engines were tested on a stand with the flywheel output fed into a 'brake' or dyno.
Old 08-11-2013, 08:55 PM
whitehause
whitehause's Avatar
ok then
Old 08-11-2013, 09:14 PM
694speed350
694speed350's Avatar
wrong the hp was never measured at the rear wheels. the engine was measured at the fly wheel with all the accesories connected. If measured at the rear wheels they woud have been 15-25 less.
Old 08-11-2013, 09:26 PM
whitehause
whitehause's Avatar
yea...got that from the last two post that said it was wrong....but thanks
Old 08-12-2013, 12:47 AM
ddawson
ddawson's Avatar
More like 50-60HP less at the wheels.
Old 08-13-2013, 05:21 AM
elle88
elle88's Avatar
also on modern cars it's always BHP , never RWhp .
there could be some exceptions but i checked some ferraris and the z06 vette and all of them report BHP
To Standards for measuring horsepower: 1969 427 compared to 1972 454?
Quick Reply: Standards for measuring horsepower: 1969 427 compared to 1972 454?
