Carb. return springs
Old Aug 12, 2013 | 10:40 AM
1978vett's Avatar
1978vett
Default Carb. return springs
My accerator, is really hard to push,I noticed that there are two return springs.. Is there supposed to be two or would it be ok to take one off ?? Thanks
Old Aug 12, 2013 | 10:53 AM
C6DuffMan's Avatar
C6DuffMan
I believe two are used in case one breaks.
Old Aug 12, 2013 | 01:50 PM
Alan 71's Avatar
Alan 71
Hi 78,
Have you tried pushing the accelerator with one spring and both springs off?
There might be another reason it's hard to depress beside the springs.
Regards,
Alan
Old Aug 12, 2013 | 01:57 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Are the springs connected correctly? Throttle cable adjusted correctly?
Old Aug 12, 2013 | 03:59 PM
7T1vette's Avatar
7T1vette
You might have accelerator cable, linkage, or pedal mechanical problems. I've not experienced any "pedal effor" problems in any C3 I've ever owned.
Old Aug 12, 2013 | 04:24 PM
The Punisher's Avatar
The Punisher
you should have 2 springs
Old Aug 12, 2013 | 05:58 PM
DC3's Avatar
DC3
I bought my '73 out in Arizona and by the time I got it back to Texas, my right leg was wore plumb out. The previous owner liked a stiff throttle and had installed two very stiff springs. I found correct springs locally and after installation the difference was like night and day.
Besides what's already been suggested to check, take a good look at the carpet under the accelerator pedal to make sure it's not somehow restricting movement.
DC
Old Aug 12, 2013 | 06:31 PM
1978vett's Avatar
1978vett
It pushes real easy with no spring at all, it is about right with only one spring... I think I will leave it like that until I order some new ones.. Thanks for all of the replies...
Old Aug 12, 2013 | 09:01 PM
maverickmk's Avatar
maverickmk
Using springs that are too heavy will cause premature wear of the throttle shaft bushings.
To Carb. return springs
