69 corvette special paint code?
Old Aug 19, 2013 | 08:03 PM
smartauto7's Avatar
smartauto7
Default 69 corvette special paint code?
On my build sheet it shows a special paint code. code 001. Any ideas what it is?
Old Aug 19, 2013 | 08:06 PM
Mike Ward's Avatar
Mike Ward
What's on the trim tag?
Old Aug 19, 2013 | 08:17 PM
smartauto7's Avatar
smartauto7
420 saddle trim/ 980 paint riverside gold
Old Aug 19, 2013 | 08:18 PM
Alan 71's Avatar
Alan 71
Hi sa7,
I believe if you look back through the thread you had about your tank sheet you'll see a post by Rowdy Rat (post #14) in which he gives his thoughts about what the Special Paint might be in this case.
Regards,
Alan
Old Aug 19, 2013 | 08:30 PM
Rowdy Rat's Avatar
Rowdy Rat
Veteran: Marine Corps
I mentioned in your other post that what is being called out is not a "special paint" color, but "special paint" attention during the paint process. Publicity purposes... GM brass... Owner with connections... Tough to say at this point why it was done. Your car has darn near every option for an L-68... Everything but side exhaust (and depending when it was built, it might not have been available). I could see it being a PR or "brass hat" car.
"Special paint" color would have been a different code for PAINT on the trim tag.
I also mentioned that your car was sent to Daniels Motors out in Colorado... That might be a good place to start your research. Perhaps they are still in business.
Regards,
Stan Falenski
Old Aug 19, 2013 | 08:31 PM
Rowdy Rat's Avatar
Rowdy Rat
Thanks Alan... I was a bit slow on this one!
Regards,
Stan
Old Aug 20, 2013 | 12:34 AM
smartauto7's Avatar
smartauto7
Alan and stan, thanks for the stright forward info.
To 69 corvette special paint code?
