Chassis Paint
Old Aug 27, 2013 | 11:05 PM
news2me's Avatar
news2me
Default Chassis Paint
I have a '77 and I want to clean up the Chassis, Upper and Lower control Arms and repaint them. What type finish should I go with, Stain, Semi-Gloss or Gloss. Also is there a special paint for the Chassis or can I go with paint from Home Depot.
Old Aug 27, 2013 | 11:18 PM
68/70Vette's Avatar
68/70Vette
People buying paints,and other stuff for repros, often buy Eastwood products. They sell a frame paint whose gloss is I think is similar to factory. I've used it extensively on the frame of my 68 and the frame of my 70. I try to get absolutely all oil and grease off of my frames before painting, but Eastwood advertises that their frame paint will stick with some slight oil contamination.
Most of my 68 frame was coated by gross oil leakage from the engine. Over the years, the accumulated oil, sand, and age had turned this into a semisolid mass. When I scrapped it off, cleaned it with acetone, etc, I had an almost mint 68 frame....no rust!!
Don't want to rave on...I used to try to have everything powder painted. It's expensive and short story, in my opinion it is not, except for some particular circumstances, cost effective. I've stopped using powder painting and gone back to paint...its a decision not driven by cost.
Old Aug 28, 2013 | 12:47 AM
80Baby's Avatar
80Baby
I had my frame chemically dipped to remove any rust and all dirt and oil/grease. It was then dipped in zinc phosphate followed by a gloss powder coating. The chassis frame looks exceptional. Absolutely no complaints and would do it again in a heartbeat. The frame is the very backbone of your car. It has to be 100%.
Old Aug 28, 2013 | 08:14 AM
MIKE80's Avatar
MIKE80
Same here.
But don't acid dip it if the frame is still attached to the car.
Old Aug 28, 2013 | 08:39 AM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
I am not sure about any product at Home Depot. Honestly, I would recommend something that is designed for painting a chassis, Eastwood has good products as 68/70 said.
I wire-wheeled the entire frame and suspension parts to remove loose rust. Power wash with marine clean, use the rust encapsulator, and then paint.
Marine Clean: http://www.eastwood.com/por-15-marin...FUqk4AodP2IARg
Here is a good "kit" from Eastwood: http://www.eastwood.com/ew-satin-ext...-kit-w-re.html
I recommend a satin finish if you want to stay close to the original finish as possible.
Old Aug 28, 2013 | 08:45 AM
Alan 71's Avatar
Alan 71
Hi n2m,
Lots of opinions on this question and people reporting good results using various finishes.
The frame was typically various degrees (even on the same frame) of semi-flat black.
Many other of the chassis parts, suspension parts, and engine compartment items, were semi-flat black too. But they TOO often varied in degree of gloss often because of the method used to paint the part.
For instance a part that was dip painted often will be a bit shinier than a sprayed part.
You mention the a-arms... these were typically shinier than the finish on the frame.
I believe you should at least take a look at the various material available from Eastwood before you buy your paint.
Good Luck!
Regards,
Alan
Old Aug 28, 2013 | 09:50 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Stock frames were painted in cheapo semi-flat black. I agree with Alan; other parts could have received what amounted to a better quality paint job.
Home Depot paint is fine if you want to go that route.
For reference, here's an 81 at St. Louis. Note the different gloss levels.
Old Aug 28, 2013 | 10:58 AM
Don Rickles's Avatar
Don Rickles
2017 C3 of Year
Is the word "paint" really correct for the chassis finish? I always considered it to be more of a "coating". Easily removed with mild cleaning such as simple green.
WB
Old Aug 28, 2013 | 12:34 PM
Alan 71's Avatar
Alan 71
Hi WB,
Since the material used on 70+ frames is described as an enamel base, (as compared to the 68-69 use of an 'asphalt' base), I'd call it 'paint'.
Perhaps the simple green removes it now because of it's surface deterioration?
Someone posted within the last couple of weeks that they were stripping exterior lacquer with Simple Green.... which is surprising to me too.
Perhaps Simple Green is now coming from China and is actually lacquer thinner tinted with tea leaves.
Regards,
Alan
Old Aug 28, 2013 | 12:53 PM
Rally68's Avatar
Rally68
Eastwood Chassis Black. They sell a satin, but I much prefer the gloss.
One note from my personal experience: Chassis black is great over bare metal but finicky about what primers it'll stick to. If there's surface rust on the part to be painted, hit it first with a rust convertor like Loctite Extend or One-Step Rust Killer & let it dry overnight before painting.
Chassis Black over One-Step is a very durable coating. We have some cast hurricane lamps that sit out on our patio from April through October. Wife brought them home and after the first night outside they were covered with rust. I wire brushed them and gave them the One-Step/Chassis Black treatment and they are just starting to show some rust at the joints after 5 years.
Old Aug 28, 2013 | 03:34 PM
7T1vette's Avatar
7T1vette
Semi-gloss for the frame....
Old Aug 28, 2013 | 05:58 PM
John 65's Avatar
John 65
Go with good old Rustoleum rattle cans or a large can that can be sprayed. Pick them up at the Home Depot and they will work just fine. I went with the gloss to help make cleaning it simple.
I used the specialty chassis paints in the past. Cost more $$$ and never really saw any advantage.
Old Aug 28, 2013 | 06:23 PM
TWINRAY's Avatar
TWINRAY
Well, I prefer the Satin
Old Aug 28, 2013 | 06:44 PM
Alan 71's Avatar
Alan 71
Hi,
I think the semi-flat hides the imperfections in the frame's surface a bit better than gloss and also is easier to touch-up without leaving a 'blush' around the area you've touched up.
I still believe it's worth the effort it takes to find the original formula Krylon #1613 Semi-Flat Black.
Regards,
Alan
Old Aug 28, 2013 | 08:54 PM
1974ta's Avatar
1974ta
Could not agree more. I used the red scotch brite pads in a drill and the 3m black pads in a drill to remove old paint and rust. They worked great! Also used a dremel with wire wheels to get in some smaller areas. This is with the body on.
Then I sprayed Rust Oleum Satin on the frame and it came out great. Cans sprayed quite nicely. I also used John Deere Blitz Black to vary the gloss on some of the other parts like the rear crossmember. The A Arms were a higher gloss than the rest so I was going to use Rustoleum semi-gloss. The Rustoleum does take a while to dry but I am extremely satisfied with the results. Really like the price!
Duplicolor makes a prep sol type aerosol to get bare metal clean and then I go over it once more with lacquer thinner for good measure before spraying.
Bill
Old Aug 29, 2013 | 03:44 PM
army's Avatar
army
For anybody living in a rural area, John Deere sells a medium gloss black enamel that looks great on frames. I have some old JD garden tractors and used it on all of them with very good results. Just the right shine and very durable. They also have a durable flatter paint called Blitz Black that's good for rough areas where too much shine is not desirable. They both come in rattle cans, quarts and gallons. You need to use their thinner too. I think Valspar makes their paint so maybe it's available under that brand name too. Here's a tractor frame I did with the medium gloss. It's a tad dusty.
This pic depicts the shine factor exactly. That's what it actually looks like in person.
Old Aug 29, 2013 | 11:03 PM
tx75vette's Avatar
tx75vette
I painted a car trailer with implement gloss black enamel from tractor supply. I think it was Valspar and cost around 45.00 for a gallon. It has been 2 years and has held up good in the sun. I think they also sell it in flat black or semi flat black. I would recommend it for a frame.
Old Aug 30, 2013 | 12:12 PM
TWINRAY's Avatar
TWINRAY
I just want to say about the Eastwood product, it covers really well. make sure you wear a resperator.
To Chassis Paint
