1981 Almost caught on fire
Old Aug 30, 2013 | 11:46 AM
chrismoore701's Avatar
chrismoore701
Default 1981 Almost caught on fire
My father in law has an 81 and had a terrible smell of smoke. Found a burned wire at the fusible link in the battery compartment. I didn't look at it real close, but what would cause this? He has not touched the battery for a long time, just drives it. The fusible link needs to be replaced, but I sure would like to know what caused it to burn. Any ideas?
Chris
Old Aug 30, 2013 | 11:56 AM
Sharkwagon's Avatar
Sharkwagon
My guess would be a bad ground somewhere due to corrosion, or a short caused by cracked insulation/crimped strain relief on wiring upstream (or both). I wouldn't think that anything more then general age and wear would be the culprit but I'll let the experts chime in.
Old Aug 30, 2013 | 03:41 PM
gkz's Avatar
gkz
What's a fusible link doing in the battery compartment?
Old Aug 30, 2013 | 05:05 PM
chrismoore701
There is a smaller red wire coming off the battery to the link and then goes into the car. The car from what I know is 95% original so I figure it is afactory
Old Aug 30, 2013 | 06:27 PM
7T1vette's Avatar
7T1vette
Might be the power wire to a sound system. If it has an aftermarket stereo system in it, the installer may not have put a separate fuse in the line. In that case, if a short develops, that feed wire becomes a "fusible link".
Old Aug 31, 2013 | 05:14 PM
Sharkwagon's Avatar
Sharkwagon
Good catch gkz I totally missed that, I was picturing one of the links in the engine bay. I'd say more investigation is in order in the wiring as it sounds like some splicing has been going on.
Old Sep 3, 2013 | 02:34 PM
chrismoore701
I am calling a fusible link, two wires coming to a junction with bolts on it. Am I correct in calling that a fusible link? or is that more of a junction?
Old Sep 4, 2013 | 04:02 PM
chrismoore701
Any one else have any thoughts
thanks
Old Sep 5, 2013 | 07:05 PM
spedaleden's Avatar
spedaleden
I think your looking at this
If this is what your looking at, this is not a fuzeable link
Old Sep 5, 2013 | 09:35 PM
Rawj's Avatar
Rawj
That red wire comes from the alternator and feeds your battery.
Old Sep 6, 2013 | 08:16 AM
chrismoore701
There are two bolts on it, not one, but looks just like that. How would I go about testing why it burned? Lucky he was on a short trip
Old Sep 6, 2013 | 08:31 AM
chrismoore701
At least I thought there were two bolts, maybe just the one. If just the one, I am guessing maybe it became loose and started to spark. your thoughts
Old Sep 6, 2013 | 12:30 PM
7T1vette's Avatar
7T1vette
A 'loose connection' spark would not cause a fire, unless there are fuel vapors in the area. A burning wire would be due to a 'dead-short' situation in the circuit fed by that wire.
Old Sep 6, 2013 | 02:35 PM
chrismoore701
The wire is definitely burned near the connections to the post I will look into it more this weekend and see whats up
Old Sep 7, 2013 | 05:48 PM
chrismoore701
It is the connector shown above. I think it is the splice connecting the battery to the alternator. I am going to take the alternator off and have it checked. I disconnected the battery when running and it died. So something is wrong there. Am I right with the cable going from the alternator to battery?
Old Sep 11, 2013 | 09:00 AM
chrismoore701
So I checked the alternator and it was fine, checked the wire, it was good. looks like the connection was loose and caused it to heat up. Changed the connector on the battery and hooked it all back up and took it for a drive and all is good
To 1981 Almost caught on fire
