Doorgunner's '68 Convertible Project
Old Jun 20, 2021 | 09:03 PM
  #5961
derekderek's Avatar
derekderek
Happy father's day Tony.
Old Jun 21, 2021 | 06:42 PM
  #5962
Priya's Avatar
Priya
Doorgunner, I was looking at your gill replacement starting on page 251. I see you installed your 68/69 gills with the front clip removed, do you think this could be done with the front clip still bonded to the car?
Old Jun 22, 2021 | 02:19 AM
  #5963
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I think You have the skill to install the gills while the clip is on the car....but I do not know if there is an "airbox" behind your '76 fender? Who knows---your car may be easier to modify than mine!
I'm guessing the problem would be the #4 gill on my car. The front of it rests against the "airbox" on my '68.
Below are pics and a couple measurements of my clip-less '68.
I think....the angled piece of fiberglass that the white arrow is pointing at is actually a remnant of the original #4 gill that the original owner did not remove when he installed the '76 "vent" into the fender.........
You can see in both pics below the 8 inch "mark"....right or wrong, that was my reference point for installing the gills....
The #4 gill normally is a "dummy-gill"....it is sealed-off so that water and dust will not be sucked into the oval vent door.......
I MAY make the #4 gill functional, but I would have to "notch" the airbox and seal the notch to keep water and dust out of the kickpanel door-vent.
When I set the clip onto the car "just to see where I am at"...I will decide about the #4 gill.
Sorry I couldn't help you very much as your car may be different behind the fender.
BUT...to repeat....I'm sure you can handle it.
Old Jun 22, 2021 | 12:35 PM
  #5964
Priya's Avatar
Priya
Thanks for the pictures and your help, doorgunner
I assume that big darker oval in the pictures is a flapper valve for interior ventilation?
Old Jun 22, 2021 | 02:35 PM
  #5965
doorgunner's Avatar
doorgunner
Yep...it's a metal "door" with a rubber seal around the edges. It allows "cool" air to blow through the louvers in the kick-panel onto your shoes when you slide the lever on the console.
If your car doesn't have that door assembly you are probably better-off/less hassle doing your gill mod. (I had those in my '69 vert Camaro and always liked the airflow ...that's the only reason I am not deleting the door-vent assemblies).
Old Jun 22, 2021 | 02:43 PM
  #5966
doorgunner's Avatar
doorgunner
In other news...the A.D.D. kicked in as I was about to finish the garage door insulation.
I saw the box of parts for the headlite Relay and decided to test-fit the piston and rod assemblies.....
I bought the 5/16" brass washers and mocked-up the piston assembly.......
one end of piston/o-ring/brass washer........
o-ring is inserted into piston-lip-seal cavity/brass washer is placed on o-ring to hold it inside the lip-seal....the other end of the piston is stacked the same way. (not shown)....
The assembly is placed onto the diaphram rod and held in place with the 4-40 tpi nut rather than risk re-crimping the tip of the rod..........
Note: As another member said...the I.D./hole in the brass washers is slightly oversize and slips past the lower crimp on the left end of the rod....
The brass washer holes will be filled with silver-solder and re-drilled to .096" so the washer will fit tightly on the rod and firmly against the lower crimp. The nut will hold the brass washer on the right end of the piston in place . (I did not try to re-crimp the right-end assembly onto the rod since I was afraid the new crimp would possibly cause the tip of the rod to break off from being too thin in the crimped area)
Old Jun 22, 2021 | 02:54 PM
  #5967
derekderek's Avatar
derekderek
4 correct size washers. kind of pricey for washers but come with some other stuff too. https://www.ebay.com/itm/233850947256 the used set i bought seem good. seller says these are good. really easy to lose those itty bitty washers...
Old Jun 22, 2021 | 02:56 PM
  #5968
Priya's Avatar
Priya
Yes, I don't think my 79 has that. I'll see if I can find some pictures of the 78-82 cars with the front clip removed to see what I might be up against.
Old Jun 22, 2021 | 03:44 PM
  #5969
derekderek's Avatar
derekderek
the vents draw the air from the wiper trough. supposed to be a piece of screen keeping the life forms out. pull the kick panel and it is right there with a vacuum can on my 75. about 100% sure it wasn't deleted from 75 to 79. possibly with nose change in 80.
Old Jun 22, 2021 | 03:45 PM
  #5970
doorgunner's Avatar
doorgunner
I don't know the year of this car......maybe you recognize the crash-bumper. IF your car has vent louvers in the kick panels it probably has the vent-door assemblies.....
?'78-'82? per Web?
Old Jun 22, 2021 | 03:56 PM
  #5971
Priya's Avatar
Priya
My car does not have vent louvers in the kick panel.
Old Jun 22, 2021 | 06:40 PM
  #5972
doorgunner's Avatar
doorgunner
ITTY BITTY???? I dropped an original washer on the floor...I'd need a telescope to find it
I ended up buying a pack of 10 bras washers 5/16" O.D.(perfect) & 1/8" I.D.( )...but couldn't find any with the ITTY BIDDIER hole in them....hence, soldering gun.
You may have dodged a big hassle if you install gills.
MEANWHILE......it took only 3 weeks to do 8 hours work/$80 worth of insulation and Aluminum HVAC tape......
TAAAA DAAA (per recovery room nurse).....
I'ma need sunglasses when I look that way
Old Jun 22, 2021 | 07:38 PM
  #5973
Priya's Avatar
Priya
I just had a look at my kick panels, they do have vents in them. D'oh!
Old Jun 22, 2021 | 11:43 PM
  #5974
doorgunner's Avatar
doorgunner
R A T S !
You STILL can handle it!
NEXT Question: Do you EVER use the vents...Huhhhhh?
Old Jun 23, 2021 | 12:35 AM
  #5975
Priya's Avatar
Priya
I think the early C3's have a cable direct to the vents, but not on my 79 that I know of. I think jts all operated through the heater/ac controls beside the fan on the centre console.
Old Jun 23, 2021 | 06:45 AM
  #5976
derekderek's Avatar
derekderek
i took a pic last night of the vent with vacruator in front of it. (new word!) tried to load it 3 times. and it jumps back to the 4l60 page. it will probably work later. there it is! and now i know what i have to do to my new garage door in north port florida if and when i get in there in the next few weeks. builders are idiots. they fail an inspection and don't do what the town failed them for before they try to have it reinspected. it is really dragging on, but these inspectors are working for ME! keeping the builders from passing on stupidity to the buyer.
Old Jun 23, 2021 | 07:59 AM
  #5977
SamTheSham's Avatar
SamTheSham
The insulated garage door looks GREAT!! Maybe you could start a new profession? I would pay to have mine done like that. Interested in traveling to S.W. Fla. for a long weekend?? No jambalaya, but lots of conch chowder.....
To Doorgunner's '68 Convertible Project
Old Jun 23, 2021 | 02:30 PM
  #5978
doorgunner's Avatar
doorgunner
I'll drive "down there" in the Vette when it's finished
Old Jun 23, 2021 | 05:59 PM
  #5979
SamTheSham's Avatar
SamTheSham
Will look forward to it. Can swap some 'benign' war stories.
Old Jun 23, 2021 | 11:46 PM
  #5980
doorgunner's Avatar
doorgunner
Ya' know the weird thing about war stories...........
No one believes them unless they have "participated".
