Doorgunner's '68 Convertible Project
Old Oct 29, 2025 | 09:32 PM
  #8241
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Originally Posted by oldcarbum
of course you did.
You are strong people!
strength in numbers ....thanks guys!!!
Old Oct 29, 2025 | 10:30 PM
  #8242
doorgunner's Avatar
doorgunner
Rookie Me...lots to grind off.....
I Ground off the excess EXCESS! Separated the fiberglass trough from the aluminum mold with the heat gun.....
Rough-sanded and trimmed to size...the blue tape cured too long and didn't want to release...Ohhhh Wellll.......
this is what the trough should look lie when bonded to the inner fender/hood edge..
The top flange goes UNDER the fender skin..........
I need to make an Inner Mold to sandwich the fiberglass so it cures with flat surfaces and sharp corners!
Now that I Have A Clue...I will fab a 2nd extension trough for the passenger fender which has NO trough because of much previous damage over the decades.
(Did I say the flange under my thumb fits UNDER the fender edge?
The hood is cocked to one side to allow for test-fitting the trough-mold)
Old Oct 29, 2025 | 10:55 PM
  #8243
OldCarBum's Avatar
OldCarBum
Good to see you’re back at it!
Old Oct 30, 2025 | 07:27 AM
  #8244
doorgunner's Avatar
doorgunner
Thanks OCB...another year/12 in a row...you guys encouraged me not to give up.
Maybe I will fab that inner mold today and make the fiberglass trough extension.
Old Oct 30, 2025 | 01:01 PM
  #8245
OldCarBum's Avatar
OldCarBum
Tony,
I’m just thinking out loud here so…..
Wouldn’t it be easier and at this point cheaper, just to purchase a complete front clip?
I’ve seen a couple posted lately.
Even getting the pieces one or two at a time may be cost effective and much less trouble?
Don’t get me wrong, the work you are doing is fantastic and I truly hope it all comes together in the end, but I’ve never seen anyone take on this level of repair.
I’ve taken on some basket cases over my years, but nothing like you’ve taken on (this is a complement).
I wouldn’t even attempt the work you are doing!
Just something to think on my friend!
Old Oct 30, 2025 | 11:21 PM
  #8246
doorgunner's Avatar
doorgunner
Tony,
WHERE CAN i FIND THESE CLIPS/PARTIAL CLIPS YOU SPEAK OF?
Your idea is sounding better and better because of me fighting the PTSD.
The main (budget) reason I didn;'t buy a used clip was to put the big bucks in the paint job.
I would make a trip to get what I need within 500 miles...may as well make a mini-vacation out of the trip since shipping would cost more than the trip.
915200 (it's an aviation thing)
Old Oct 31, 2025 | 12:52 PM
  #8247
OldCarBum's Avatar
OldCarBum
Mulikins is a Corvette salvage yard.
I’ve found several impossible to find pieces for my car on their website and especially by calling them
They have always been helpful and their customer service is top notch.
The items they have shipped to me have always been exactly what I needed.
Run an add in the want to buy section and see what turns up.
I remember not to long ago someone posted a complete front clip in the parts for sale section.
Even if you get one section like a fender at a time, it might be better than what you must be going through.
I’d get PTSD just thinking about it.
Old Oct 31, 2025 | 07:19 PM
  #8248
litevette's Avatar
litevette
Great tip on Mulikins!
Watching what you’ve been dealing with on the front clip I have many times thought that you are definitely cut from a different cloth than me for sure.While I applaud that you have the skills and tenacity to get it done (which am lacking), I’ve also thought about the stress inducing part being that you get one area corrected just to find that another area has now gone and decided to move on you. If I had hair, I’d have none after such a bout. But then again, yer a battle tested “get it done and get it done with what you’ve got” soldier!
Old Oct 31, 2025 | 11:54 PM
  #8249
doorgunner's Avatar
doorgunner
Thanks, Men!
The first fiberglass trough I made is on the left......the other two pieces are the 1st mold and the new outer mold which will make it easier to trim the future sections of the trough to size.....(I think)
The fiberglass w/resin is laid on the inner mold....the outer mold s then clamped into place to make a neater looking trough....I took industrial scissors and trimmed off the excess fiberglass as soon as the molds were clamped together (time for a new pair of scissors)....
I took Ya'lls advice and used less hardener-then I put the assembly outside in the sunlight to cure......(hard to tell what is going on in the pics/sorry 'bout that)
I may have to make one more section of trough....maybe...but the inner/outer mold set made the job go about 70% faster.
Old Nov 1, 2025 | 12:29 AM
  #8250
doorgunner's Avatar
doorgunner
Look what UPS brought me......a brand spanking new inside-the-dash a/c blower unit!
Good thing I did the a/c plumbing a couple months ago....
Since the radio was D.O.A....I gutted it and will install the switches(minus the aftermarket bezels) into the radio face plate
914200
Old Nov 1, 2025 | 12:39 PM
  #8251
doorgunner's Avatar
doorgunner
The final repair-trough is done...the two-piece mold/upper-lower halves helped a lot...to give the fiberglass some 90* corners...
(don't tell my wife I washed the grinding dust off it in the lavatory)....
Now I can grind off the old trough remnants on the inner fenders and epoxy the repair troughs into place.
Old Nov 2, 2025 | 12:48 AM
  #8252
OldCarBum's Avatar
OldCarBum
All very nice!
Old Nov 2, 2025 | 01:15 AM
  #8253
stingrayiii67's Avatar
stingrayiii67
I was thinking of doing this also, let me know how well it works.
Old Nov 2, 2025 | 09:43 AM
  #8254
doorgunner's Avatar
doorgunner
I will post the outcome this week I HOPE!.
It should be O.K.
I have to buy six 90* pvc elbows to attach to the blower box...attach THE BLOWER BOX TO THE FIREWALL the ends of the flexible ductwork to the elbows.....connect the prewired 12V feed wire and ground wire, also.
The trick will be fitting the blower speed control swtch and the Thermostat switch into the radio faceplate to keep"the original look.
I MAY leave the radio as is and use the console control cables to operate the two switches using 2 bellcranks rather than 2 switch *****...the switches would be hidden behind the passenger lower dash panel and bolted to the blower box.
YEP...my PTSD said to use the cables.
Gotta go to home de-pot and get 6 elbows...then remove the OEM air/heater box and store it in the attic.
Old Nov 3, 2025 | 03:51 PM
  #8255
doorgunner's Avatar
doorgunner
Slowly I turn,,,,,,,I had to enlarge the elbow I.D.s so they would fit on the new blower housing...
Blower housing outlets from factory
Elbows assembled/painted/installed to accept duct work.....
There are 6 duct ends that will attach to the elbows on the new blower housing...........
THAT'S enough for today!
Old Nov 3, 2025 | 04:03 PM
  #8256
doorgunner's Avatar
doorgunner
4 TRIES...THE PICS WON'T POST!
FIVE TRIES............
Old Nov 3, 2025 | 07:16 PM
  #8257
litevette's Avatar
litevette
I’m seeing the pics Tony. Looking good too!
To Doorgunner's '68 Convertible Project
Old Nov 4, 2025 | 09:51 PM
  #8258
doorgunner's Avatar
doorgunner
TWO many home repairs today...I didn
t start on the blower box installation yet...but I DID eyeball the firewall while I was in/out the garage.
Old Nov 5, 2025 | 03:51 PM
  #8259
doorgunner's Avatar
doorgunner
A little more progress.....the firewall is de-blowered........
The air box is removed.......
I needed a space 15" deep x 16" wide x 9" high. Good news...I have 17" deep x 19" wide x 12" high.
I will store the heater/blower in the garage attic.
Tomorrow the new A/C airbox with heat/cool will be installed IF God says the same.
Old Nov 5, 2025 | 04:08 PM
  #8260
TKX 5-SPEED C3's Avatar
TKX 5-SPEED C3
Good Luck!
