Doorgunner's '68 Convertible Project
Old Jan 12, 2026 | 11:04 AM
  #8401
loup68's Avatar
loup68
Army
It is wonderful to read that you can finally drive your car Tony!!! Lou.
Old Jan 12, 2026 | 11:52 AM
  #8402
OldCarBum's Avatar
OldCarBum
When you get the front clip on and painted, I have a bottle of champagne I’ve been saving in the fridge!
I’m going to crack that thing open and toast you and your 68.
Old Jan 14, 2026 | 12:22 AM
  #8403
doorgunner's Avatar
doorgunner
2026 Loser of the Year
NOT YET, LOU.....I still have to repair the driver fender. But I;m closer!
I'll drink (Ensure) to THAT !!!
I have to fab two supports to mount the condenser tomorrow...maybe?
Old Jan 14, 2026 | 09:11 PM
  #8404
doorgunner's Avatar
doorgunner
The radiator is about finished. I have to seal some gaps to keep the hot air going down under the engine instead of going past the upper & lower radiator hoses where they enter the rear wall of the hot air deflector.
The radiator is in place and clamped......The condenser is in place and pusher fan is mounted......
Not much to see here...not enough shoulder room to get an overall pic. This is inside the hot air deflector with the puller fan ready to boost the hot air coming thru the condenser and radiator and blow it down under the engine.....
Tomorrow I will reconnect the wires to the pusher fan which is on the condenser, and reconnect the 10 second delay relay to the Puller fan on the bc side of the radiator (to prevent power surges from both fans turning on at the same time (per experienced members)
Old Jan 15, 2026 | 07:31 AM
  #8405
litevette's Avatar
litevette
Glad I read your post Tony. I had not read about the power surge stuff. You just saved me some possible headaches, so thanks for that!
Old Jan 15, 2026 | 10:56 AM
  #8406
doorgunner's Avatar
doorgunner
I "learnt" that from other forum members.
Old Jan 15, 2026 | 12:58 PM
  #8407
OldCarBum's Avatar
OldCarBum
That is a great reminder Tony.
There are also threads where many members use a soft start system on their electric fans to keep the power spikes to a minimum.
Old Jan 15, 2026 | 03:13 PM
  #8408
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I had the DeRale PWM soft start and it lasted only one 1 season....went through 2 before I gave up on the soft start systems.. I use the Dakota Digital programmer. It still works fine after 2 seasons. ITs not soft start but I can set the start temps for 2 fans at 2 different settings. I also run a seperate main power 6 lug buss bar off the main cable from the starter so the alternator wont wouldnt see a spike for each fan. The trigger for the relay coming off the controller. The battery itself absorbs the spike
Old Jan 15, 2026 | 03:37 PM
  #8409
doorgunner's Avatar
doorgunner
OCB...I bought a PCM module a couple years ago but the PTSD wouldn't let me program it
Thanks for the idea, though
R.R. AAAHaaaaa...You answered that question before I asked!
.I was getting my little brain focused on reconnecting the fan pusher and puller wires that run to the relay box. I'll rewire the two fan #30 relays (one relay is instant-on/the other relay is 10 second delay-on just to be safe) terminasl to get power from the bus bar I installed last year (next to the firewall relay box). .....and use the temperature switch as a ground connection to turn on the fans,
Thanks Guys for keeping an eye on me.
NOW...to find the front fender splash shield so I can fab a driver side shield
(UNLESS I find one in the Parts For Sale Forum)
Old Jan 16, 2026 | 04:21 PM
  #8410
doorgunner's Avatar
doorgunner
I found a pair of "Splash Panels" which normally are part of the inner fender. It;s nasty looking, but both pieces for $70 was a deal conpared tp buying both inner fenders for $700. Ill dress it up/repair some notches and holes for installation into the front of the passenger fende for shape and support......
I wore my little self out getting that piece...I'll go back to the car collectors yard in a day or two to remove the driver's side splash panel.
Old Jan 17, 2026 | 03:54 PM
  #8411
doorgunner's Avatar
doorgunner
I started doing minor fiberglass repairs to the passenger side splash panel....just removed from donor car...
Vleaned up for repairs/////
Sheetmetal backing over holes to support fiberglass on opposite face.....
I'll let it cure and build up opposite side with more fiberglass...then sand smooth.
Old Jan 17, 2026 | 08:46 PM
  #8412
doorgunner's Avatar
doorgunner
The sheetmetal supports are removed.......
The repairs are fiberglassed on both sides now. I will sand them down tomorrow and fit the splash panel into the underside of the passenger fender......
Rather than a rubber seal at the top of rhe shield I will fill the gap in with fiberglass for more support.
Old Jan 17, 2026 | 11:26 PM
  #8413
OldCarBum's Avatar
OldCarBum
Looks good!
Old Jan 18, 2026 | 04:11 PM
  #8414
doorgunner's Avatar
doorgunner
I finally got the house projects (for the day) done....headed to garage to sand and fit splash panel...be back with more EXCITING PICS later
Old Jan 18, 2026 | 07:25 PM
  #8415
doorgunner's Avatar
doorgunner
NOPE..couple more home projects...but I did a little to the splash shield.
I sanded the repairs smooth and covered the whole panel with some HOT resin (extra hardener) except for the edges that will get panel adhesive....I made the repairs thicker than the oem shield.....
Maybe I will fit it to the fender tomorrow
Old Jan 18, 2026 | 08:26 PM
  #8416
OldCarBum's Avatar
OldCarBum
Looking good!
Old Jan 18, 2026 | 10:26 PM
  #8417
doorgunner's Avatar
doorgunner
SON OF A .....MY ENTIRE POST DISAPPEARED!
Taking a contour reading before I mock up the shield......
The VOID! Some fiberglassing to do at the headlight opening.........
The shield and frame extension "mocked up".......
DOES ANYONE HAVE A MEASUREMENT FROM THE BOTTOM OF THE SPLASH SHIELD TO THE SHOULDER AT THE BOTTOM OF THE FENDER???
To Doorgunner's '68 Convertible Project
Old Jan 19, 2026 | 03:28 PM
  #8418
doorgunner's Avatar
doorgunner
Old Jan 19, 2026 | 03:37 PM
  #8419
Rescue Rogers
as soon as I get home...about 5 pm east coast
Old Jan 19, 2026 | 05:07 PM
  #8420
Rescue Rogers
5.45" ish to the vertical of the rollover
