thats a great job and good progress. This type of restoration keeps me inspired to continue on my projects. thanks for the photos of what is being done.
C3 of Year Winner (appearance mods) 2019
One thing I just thought of to add to your list of things to do: in the background of the last photo I can see some shelves with trophies on them.
Might as well add to your list: make more shelves.
Been off line for several weeks working on my latest headache. I am putting a six point cage in my 68 roadster. Designed it so the body can be removed without cutting the bars from frame. Each leg fore and aft will slide out after bolt removal. For all the die hard drag racers, yes I know a bolt in cage is only approved for 10 seconds or slower but that should work fine for my application. The main hoop and passenger side swing out is complete. More to come, I hope.
Roll bar and seats are complete ! No fun making all this junk fit.
At this point while you are still fitting the roll bars in place why not weld in a bar the right height for a harness bar for harnesses through those seats. The one cross bar there is low for that, could weld in a bar across the perfect height to connect to.
Finished the Dynamat install. Just got the new cowl induction hood and set it on to see if I will go this route. Should have plenty of room now for the Shafiroff big block bullet!!!!
