Oh no, another 68 vert project
Old Apr 21, 2014 | 06:55 PM
  #41
persuader's Avatar
persuader
Awsome build dude! Just awesome!
Old Apr 21, 2014 | 10:28 PM
  #42
n.g.hayes's Avatar
n.g.hayes
Hi Lupi,
On the drivers side, I covered a larger area of the firewall because we knew where all the holes would need to be. On the passenger side, not as high due to vintage air going in. Several areas will need to be cut out for air box and lines to pass through. I can go back later and finish it off.
Thanks for asking,
Norm
Old Apr 22, 2014 | 12:40 AM
  #43
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Edited:
Originally Posted by n.g.hayes
........ Just got the new cowl induction hood and set it on to see if I will go this route.......
You MUST be a tall guy........I would have to put 3" risers under the driver's seat frame to see over that great-looking hood
Old Apr 22, 2014 | 06:31 AM
  #44
Günther-C3's Avatar
Günther-C3
Which upper a-arms are you running? Do they add caster as well?
Old Apr 22, 2014 | 01:16 PM
  #45
n.g.hayes's Avatar
n.g.hayes
Hi Gunther,
The upper a-arms are part of the suspension package from Speed Direct. Better known as SHARK-BITE coil over front and rear package. And yes, the caster is adjustable. Here are a couple of pics.
Hope this helps,
Norm
Old Apr 22, 2014 | 01:58 PM
  #46
rogman16's Avatar
rogman16
That looks fantastic!!!
Rogman
Old Apr 22, 2014 | 02:37 PM
  #47
Brandons72vette's Avatar
Brandons72vette
HEY DOORGUNNER,
That driveway is 20 plus years old. It gets real good sealer every couple years. I KNOW A GUY !!!!
BRANDON,
Got those trailing arms from Corvette Guys in Beloit, Wisconsin. No core charge at that time. May have changed by now. Super nice pieces.
…I am almost afraid to ask how much they were…almost…..
….so how much were those pieces of art?
Old Apr 22, 2014 | 03:26 PM
  #48
n.g.hayes's Avatar
n.g.hayes
Hello again Brandon,
The price , I think , is very reasonable. $1150 for a pair and that includes everything. You can look him up on Ebay under Corvette offset trailing arms. He has a super good rating and I can see why. All you do is bolt these on and no dealing with E-brake adjustment or bearing tolerance. Well worth the money in my opinion.
Hope this helps,
Norm
Old Apr 29, 2014 | 04:52 PM
  #49
n.g.hayes's Avatar
n.g.hayes
Had to custom build my safety loops for half shafts and driveshaft. The new offset trailing arms were a little bit of a challenge but plasma cutters and welders will work wonders. Hardest part is bending six loops to match up.
Norm
Old Apr 29, 2014 | 05:32 PM
  #50
SB64's Avatar
SB64
Default 68 frame off
Norm things are looking great. Nice job of fabricating shaft loops. Frame looks awesome. See you at ZIP.
Old Apr 29, 2014 | 11:49 PM
  #51
doorgunner's Avatar
doorgunner
Outstanding work (as usual!!!!!!!!!!!!)
Old May 1, 2014 | 06:52 AM
  #52
midigike's Avatar
midigike
I will keep watching this post and when you are all done I will give you my 68 vert for a complete redo. I wouldn't wan those fab skills to go rusty great job man
Old May 11, 2014 | 07:59 PM
  #53
n.g.hayes's Avatar
n.g.hayes
Thanks guys for the thumbs up on this project. Dropped the bullet in today. Got back from Shafiroff at one AM Saturday. Numbers on dyno were pretty good. Had 706 on torque and 742 for horsepower. Not bad for a hydraulic cam setup. Sorry I missed the ZIP show but man my old body was due for some snooze time. Drove up Thursday night for a 9 AM Friday dyno and never got any sleep. Loaded the motor and drove straight back to Virginia. Hope you like !!!
Old May 11, 2014 | 08:05 PM
  #54
SB64's Avatar
SB64
Default 68 vert
Hey Norm, sorry you missed ZIP would have liked to meet you. I can certainly understand why. The motor looks fantastic. That will be some wild ride when you are done. Keep up the great work.
R
Old May 12, 2014 | 11:10 AM
  #55
doorgunner's Avatar
doorgunner
I'm certain your carb cost more than my engine rebuild
Your engine looks GREAT!
Old May 12, 2014 | 12:52 PM
  #56
Günther-C3's Avatar
Günther-C3
Old May 12, 2014 | 12:53 PM
  #57
CA-Legal-Vette's Avatar
CA-Legal-Vette
I absolutely love the work that you're doing. That motor should be a monster which should push the limits on your 10 second rollcage. A good problem to have. i also now understand why you went with the big scoop, cowel hood.
I really like the custom mounts for the safety loops. I have a more stock setup but never liked the security of the loops. I always thought they'd fall off before the shafts would.
I might have missed it earlier but did you paint or replace the gas tank? If paint, did you use the Eastwoods coating?
To Oh no, another 68 vert project
Old May 12, 2014 | 03:02 PM
  #58
n.g.hayes's Avatar
n.g.hayes
Hello CA,
To answer your question, the tank is new from ZIP Corvettes. My old one was too far gone to save. Hope this helps and thanks to all the members that follow this build. I still have a long road ahead. My bank account took a big hit these last two months with my daughter getting married and a trip to Shafiroff !!!!!
Norm
Old May 12, 2014 | 03:27 PM
  #59
doorgunner's Avatar
doorgunner
Hang in there n.g.....................
my bank account would have gone BYE-BYE after the engine....
the wedding would have been on Master Card!
Old Jun 22, 2014 | 01:48 PM
  #60
n.g.hayes's Avatar
n.g.hayes
Completed a couple more small projects so time to post more pics. Fuel system from Aeromotive is bolted down with rubber bushings. Water pump, starter and goose neck on engine. One ground station mounted in rear for everything on that end of the car. Turbo 400 by Rossler is being built, two weeks out. Torque converter from Pro Torque due any day. Hope to remount body for last time by late July. Money and patience have run out, still got time on my side if I can keep waking up above ground each morning!!!!
Norm
