headlights
Old Oct 9, 2013 | 12:47 AM
tomgaz's Avatar
tomgaz
Default headlights
Ijust bought a 1974 all of my lights keep on going on and off every 3 seconds. Not sure what it can be. Any help would be appreciated.
Old Oct 9, 2013 | 07:02 AM
Rotonda's Avatar
Rotonda
The symptoms sound like a self resetting circuit breaker doing its job.
Old Oct 9, 2013 | 11:27 AM
tomgaz's Avatar
tomgaz
Can you tell me where it might be located?
Old Oct 9, 2013 | 11:56 AM
tomgaz's Avatar
tomgaz
When the car is in park they stay on.
Old Oct 9, 2013 | 05:19 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The switch itself has a breaker located inside. If the breaker is bad it will cause the lights to flash. I'm not sure what metal its made from but it responds similar to beryllium in that heat makes it curl, coolness makes it go back.
If the headlamp switch isn't the problem, which from what you say.. "when in park they stay on" Then you probably have a major short somewhere. How about Neutral... Same response or different?
Willcox
Old Oct 9, 2013 | 06:56 PM
tomgaz's Avatar
tomgaz
Can someone tell me the trick on getting the rod out of the light switch that is connected to the ****. Thanks
Old Oct 9, 2013 | 07:45 PM
0Willcox Corvette
Former Vendor
Yes.. but before you remove it... Do the headlamps flash when the car is in neutral???
On the back (bottom) of the switch is a release button.. turn the switch all the way to the left and push the button inward, this will release the ****.
Willcox
To headlights
