Front bumper
Old Oct 12, 2013 | 08:17 AM
~Stingray's Avatar
~Stingray
St. Jude Donor '17, '19
Default Front bumper
Hey guys,
Quick question about the front bumper. I am having some work done on the car to repair a sideswipe. The front bumper needs to be repainted.
The question is, should I buy an aftermarket bumper and get rid of the urethane one? I plan to keep the car for a long time so if I go to sell it in 20 years would the original bumper make a difference?
The bumper is not covered in the repair cost as it was damaged when I bought it. So it would be cheaper to buy a fiberglass bumper and just have it painted than to have to strip the old one, reprime and paint again.
I know fiberglass ones look better because there is not really any give to cause waving. But if the majority thinks the value would be affected then I may keep it?
I have to replace some body panels so the entire car will not have original body panels anyway.
Thanks.
Old Oct 12, 2013 | 09:12 AM
MidShark's Avatar
MidShark
I don't think it would have much impact on value. In fact, if you plan to keep the car for 20 years, you would probably be way ahead if you replaced it now. My '75 needed both bumpers replaced because they were so brittle they were falling apart.
Old Oct 12, 2013 | 05:09 PM
~Stingray's Avatar
~Stingray
Oh, I hadn't thought about it falling apart.
Old Oct 12, 2013 | 06:33 PM
Ratfinkharley's Avatar
Ratfinkharley
The fiberglass bumpers have fitment issues. The labor to fit the bumper to the car offsets some of the difference between fiberglass and polyurethane.
I'm a bit of a purist and would replace the old polyurethane with a new polyurethane bumper. It is probably at the end of its lifecycle and not worth stripping/repainting. All that would do is eventually fail with new paint on it.
Do what makes the current owner, you, happy and not the "new owner" 20 years from now. A lot can happen between now and then; hopefully many happy miles.
Old Oct 12, 2013 | 07:24 PM
dochorsepower's Avatar
dochorsepower
Yes, the original urethane bumper covers get brittle and fall apart. I had to replace mine 20 years ago. A suggestion is to get the new flexiglass versions. They are the best of both worlds. They are fiberglass but with a flexible resin compound.
Old Oct 12, 2013 | 07:45 PM
kdf1986's Avatar
kdf1986
I would go with the fiberglass one. If you plan on keeping your car 20 more years, then maybe the polyurethane one will need replacing again. Can you imagine how expensive that will be in 2033?
kdf
Old Oct 13, 2013 | 07:56 AM
~Stingray's Avatar
~Stingray
Are the flexiglass ones special order or is that what all the after market venders sell?
Can you guys post links to the figerglass vs the flexiglass?
Are there any issues with flexiglass. I thought bending and flex was bad because then it will cause the paint to crack. Whats the advantage of flexiglass?
Old Oct 13, 2013 | 04:47 PM
qwank's Avatar
qwank
the '80 bumpers aren't known for falling apart. they fixed that issue somewhere around '76. the '80 bumpers do warp though, something to keep in mind. I would see if your stock bumper is repairable, that one will have the best fit
Old Oct 13, 2013 | 06:30 PM
Phil Zell's Avatar
Phil Zell
flexiglass or fiberglass would be my call
Old Oct 13, 2013 | 08:23 PM
540 vette's Avatar
540 vette
I put a flex glass on my car (80) and it didn't fit. The d/s of the bumper stuck out about 1/2 inch. And the edge by the d/s front wheel well didn't line up. I was molding the bumper in so I cut what I needed and molded it in.I met someone who also used one on his 82 and it fir the same. If you do with the flex be prepared to get some work done on it.
Old Oct 13, 2013 | 09:11 PM
~Stingray's Avatar
~Stingray
What is the difference between flexiglass and fiberglass?
Old Oct 14, 2013 | 09:29 AM
540 vette's Avatar
540 vette
The flex bumper has some flex in it like the stock one. I have found that the fiberglass in it is much thinner than the regular fiberglass one.
Old Oct 14, 2013 | 04:52 PM
~Stingray's Avatar
~Stingray
Is there really an advantage for one over the other?
Old Oct 15, 2013 | 08:00 AM
540 vette's Avatar
540 vette
The flex gives the appearance of the original because it has some flex in it. It is supposed to also be easier to fit into place. I have never heard of problems with the rear bumpers. The fronts are another story.
Old Oct 15, 2013 | 11:28 PM
Green76's Avatar
Green76
I was going to replace my front bumper that is now cracking with an OEM reproduction Urethane bumper for my 76 vette, but it looks like it has been discontinued, I checked with Zip Products, Ecklers and Willcox Inc. so I'm out of luck.......
I didn't want a fiberglass bumper but that is my only choice now......
Two years ago I replaced my back bumper with an OEM reproduction Urethane bumper and it bolted on without any problems and no body work needed.....
Good luck...
Ulf
Old Oct 16, 2013 | 12:04 AM
LS4 PILOT's Avatar
LS4 PILOT
I have heard that front bumpers can be a real pain to install using fiberglass . The old rubber style is way easier to install to match up. I found a nos GM front aBout 8 years ago and it's still looking good , but my car is garaged and out of sunlight.
I have a tru flex rear bumper. , its been there maybe 7 years I guess, it is holding up great.
The installer told me it was pretty nice fit , but it was rear of course.
I can see the diff in the tru flex and my old original GM rear bumper. The original shape was nicer I think.
I think I would go GM on the front ...if only to make it easy to install
Old Oct 16, 2013 | 10:50 PM
~Stingray's Avatar
~Stingray
What is tru flex and how does that compare to the flexiglass and fiberglass?
To Front bumper
Old Oct 17, 2013 | 03:35 AM
540 vette's Avatar
540 vette
True flex and flexiglass are the same thing.
Old Oct 28, 2013 | 09:30 PM
~Stingray's Avatar
~Stingray
I am somewhat resurrecting this thread.
I think I am going to go with the fiberglass bumper. Does anyone have venders to purchase from that they recommend or know of promo codes that can be used?
Is the flexiglass a lot cheaper than the regular fiberglass bumper?
Old Oct 28, 2013 | 10:40 PM
mrmagrath's Avatar
mrmagrath
Tru-flex is a bit dearer I think, but Willcox has deals for Forum members. I got mine from them. The more work you're prepared to do to fit them, the better they look.
