dying a vinyl top
Buddy
Make sure that you mask off all of the glass and trim too.
Clean the top really, really well with detergent. Then, rinse the heck out of it to get all the detergent off. Let dry completely.
Get a pint of SEM [liquid] "ColorCoat" dye (formal title is 'recoloring agent') from a pro auto paint supply store. They can mix it to any color you want. If you have spray equipment, great. If you don't, buy a Pre-Val gas/bottle sprayer there, also. It's about $10; also buy a couple more of the gas canisters.
Mask well before spraying and give the top a last-minute wipe down with some lacquer thinner on a lint free cloth. Now, shoot 2 or 3 light, covering coats of the vinyl dye. The dye is thin, so don't shoot so much that you get runs. But, if you get a run, don't wipe it; just let it dry. Shoot another coat after about 15 minutes. Repeat as necessary, but more than 3 coats is excessive. Usually, 2 will do on most surfaces.
Finally, when you get done and it's dry, buy a polymer protectant to put on the top...like, Mequiar's for plastics or Nu-Vinyl (my all-time favorite for plastics, rubber and leather). The polymer coating will last for weeks, will not peel or turn yellow, blocks UV rays, and will make the top look like new FOREVER. Trust me on this. NO MORE ARMOR-ALL FOR THE TOP.
If the top material is still in good condition and just needs a re-color job, this IS the way to go.
again thanks to all who took time to read my post and reply.
Buddy
