Frame/axle alignment issue
Old Oct 26, 2013 | 04:37 PM
TxC3Lover's Avatar
TxC3Lover
Cruising
Default Frame/axle alignment issue
I'm a newbie here and a new first time C3 owner. I recently bought a 1974 coupe with a L82 engine. I guess I didn't do enough due diligence as I discovered a problem today while I was doing some cleaning of the frame that I wasn't aware off. Seams the frame has some damage and the result is that the axle u-joint has breached the passenger compartment. I have attached some pictures. The car wasn't running when I bought it as the previous owner had stripped the upper block down to do some resto rod work and ran out of time and money. My goal was to get the car running and make a low budget project out of it. But now I don't know if this frame issue can be overcome? Any thoughts? Thanks!
Old Oct 26, 2013 | 06:30 PM
RDCRIS's Avatar
RDCRIS
Looks like a u-joint broke at some point. Very common problem. Same thing happened to my car when I bought it 20 years ago I thought the frame was bent too.
Old Oct 26, 2013 | 06:54 PM
'75's Avatar
'75
That's a bent frame!
Old Oct 26, 2013 | 07:52 PM
RDCRIS's Avatar
RDCRIS
It's hard to see what is going on here. Are you talking about the 3rd picture? When that half shaft is flopping around in there at speed its going to dent up things it hits. When mine went out it bent the strut rod, spring and the cross member.
Old Oct 26, 2013 | 07:55 PM
'75's Avatar
'75
That left frame rail in the 3rd pic looks like the car was rear ended and buckled it.
Old Oct 26, 2013 | 08:55 PM
TxC3Lover's Avatar
TxC3Lover
Cruising
Thanks for the comments. The rubber bushings on the strut rod look spent too. In your opinion, based on these poor pictures, is this something that a frame shop can correct? Would taking out that buckle "pull" the wheel assembly forward and provide more clearance between the u-joint and the body? Just eyeballing it I can't see it dog tracking but the clearance between the half shaft and the body seems very tight.
Old Oct 26, 2013 | 09:42 PM
'75's Avatar
'75
I think it would be good to take it to a body shop and get their take on it. It's hard to tell from the pictures.
To Frame/axle alignment issue
