Gasket to replace bladder???
Old Nov 19, 2013 | 06:58 PM
7tSixStingray's Avatar
7tSixStingray
Default Gasket to replace bladder???
Can I use this gasket from Ecklers to replace the bladder in my 1976 gas tank? I don't want to reuse the bladder gasket and I don't want to use any type of sealer on the inside of the tank. Good idea or bad idea?!
Old Nov 20, 2013 | 10:50 AM
MelWff's Avatar
MelWff
The gasket is for the sending unit, maybe I dont understand your question, but what does that have to do with replacing the complete bladder?
Old Nov 20, 2013 | 11:49 AM
SteveG75's Avatar
SteveG75
You still need the bladder to provide the nuts inside the tank that the bolts go into. The nuts are integral to the bladder.
Old Nov 20, 2013 | 08:28 PM
mds3013's Avatar
mds3013
So you want to remove the bladder completely. It is amazing to me how G.M. ever got that thing into the tank in the first place. I think the nut holder ring is a removable piece from the bladder. Too dark to go ck. the old one I have. The gasket is what you use when removing the bladder or replacing the tank. mike...
To Gasket to replace bladder???
