Rolling Chassis Pictures please
Old Nov 20, 2013 | 11:14 PM
redcruz1120's Avatar
redcruz1120
St. Jude Donor '09
Default Rolling Chassis Pictures please
Last weekend I pulled the body off. Now Im preparing the frame to be sent out to get it powder coated. I would like to see some pictures of completed rolling chassis so I could get Ideas of what to do with mine. Im thinking of semi gloss black for frame , but what about everything else?? like suspension, Springs , calipers, Ect, Ect.. . Thanks guys and galsmy finished product depends on your ideas!!
Old Nov 21, 2013 | 01:42 AM
13611's Avatar
13611
Here's a few of my 68.
Old Nov 21, 2013 | 08:03 AM
MIKE80's Avatar
MIKE80
Acid dipped and powdercoated TIGER Drylac Flame Red.
Old Nov 21, 2013 | 08:22 AM
rosslato's Avatar
rosslato
Just Spectacular Mike80
Old Nov 21, 2013 | 08:28 AM
MIKE80's Avatar
MIKE80
Old Nov 21, 2013 | 09:02 AM
PUNISHER VETTE's Avatar
PUNISHER VETTE
I'd call mine the budget build... Was going to just paint it but decided since i had a powder coater I'd try that. Did 8" sections at a time till I was done with my propane heater....It worked but...not the best use of time.
I wish I could have acid dipped it. No way to get rust out of the inside without doing that...
I had gloss black so that's just what I went with. Most of the suspension and parts I do in flat.
dusty frame in this pic.
These suspension parts were painted back before I had powdercoating. I'll redue them some day.
(I know..not the safest with the tank that crooked but it worked out okay)
Old Nov 21, 2013 | 11:12 AM
my 76 ray's Avatar
my 76 ray
Old Nov 21, 2013 | 11:39 AM
GT's 78's Avatar
GT's 78
The guy with the red chassis, WOW! Here's mine.
[URL=http://s1279.photobucket.com/user/gtbr549/media/Corvette/DSC02640_zps58eb7b45.jpg.html]
Old Nov 21, 2013 | 01:41 PM
SLVRSHRK's Avatar
SLVRSHRK
[QUOTE=GT's 78;1585485702]The guy with the red chassis, WOW! Here's mine.
Hey GTs 78,
It looks like we are close to each other and in the same boat; body-off, AP TKO conversion, Borgeson steering, etc.
I noticed that you mounted the tranny directly on the rubber mounts and was wondering if you checked your driveline alignment at that point. A lot of folks with that tranny, me included, have found that we need to use about a 1" spacer at the tranny rear to get the alignment angle correct.
What I noticed is that when the angle is set correctly, the carb pad is just about level and it looks like (from the pic) that your carb is angle towards the rear.
Just trying to save you a vibration later on.
By the way, I'm in Hillsborough, NC. If you want to talk or come by and compare notes, just send me a PM.
Cheers.
Old Nov 21, 2013 | 07:50 PM
72LS1Vette's Avatar
72LS1Vette
Rick B.
Old Nov 22, 2013 | 06:50 PM
redcruz1120
St. Jude Donor '09
That is beautiful!! What color is the Body going to be??
Old Nov 22, 2013 | 09:25 PM
RobRace10's Avatar
RobRace10
Old Nov 22, 2013 | 09:52 PM
mark6669's Avatar
mark6669
Stock 72
Custom 69
Old Nov 24, 2013 | 11:25 PM
redcruz1120
St. Jude Donor '09
What is Acid dipped??? who usually does that? The powder coater??
Old Nov 25, 2013 | 01:37 PM
MIKE80's Avatar
MIKE80
Thanks Still have body work and new paint to do, but this is how it sits now. I haven't decided on final color yet. It will be a while before I tackle the body.
As far as the acid dipping goes, I dropped it of at the company that did the acid dipping and this is the acid dipping process that my frame went through; They bake the parts, then dip in hydrochloric acid, and then dip in neutralizer. The parts get several power washes. Last power wash is with zinc phosphate which will keep flash rust off the parts for several weeks. The powdercoating company works with this company also, so they picked it up from them and did the powdercoating for me. I just dropped it off at the one place and picked it up from the powdercoat company after it was finished.
Old Nov 25, 2013 | 01:59 PM
Tim 1973's Avatar
Tim 1973
Old Nov 25, 2013 | 05:36 PM
brent319's Avatar
brent319
C3 of Year Winner (appearance mods) 2019
I had my frame sand blasted and powder coated a gloss black locally for about $350. I thought that was pretty fair.
To Rolling Chassis Pictures please
Old Nov 26, 2013 | 09:49 PM
Smooth72's Avatar
Smooth72
An old project about to restart. Frame welded up, Powdercoated, VBP suspension.
Old Dec 5, 2013 | 01:43 AM
redcruz1120
St. Jude Donor '09
What are the silver aluminum looking caps on your rear crossmemebr??
Old Dec 5, 2013 | 11:38 AM
Smooth72's Avatar
Smooth72
VBP calls it a cross member reinforcement, to stiffen the rear cross member.
http://www.vbandp.com/auto-parts/c2-...category_id=48
