Door skin separation
Old Dec 1, 2013 | 11:23 AM
rene040269's Avatar
rene040269
Default Door skin separation
Hi Guys, this morning i noticed that the lower part of my passenger side door ('80 Vette) was not lining up with the rocker panel and was sort of bulging out half an inch or so. Further investigation shows that the door skin was not attached in the middle of the door anymore, only on the front and back of the door. It looks like the fiberglass skin is separating from the steel inner door. I could stick my finger in the gap in the bottom of the door.
Does this sounds familiar/does this happen often?
Can i re-bond it or do i have to take the skin completely off before glue-ing it back on?
Thanks for sharing.
Old Dec 1, 2013 | 11:46 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Rebond it without attempting to remove the door skin from the door.
Old Dec 1, 2013 | 03:00 PM
rene040269's Avatar
rene040269
So the route to take is clean the gap, put adhesive in it and clamp it in position until the bond is cured?
Wondering why this happens, just 33 year old adhesive finally givin'up?
Old Dec 1, 2013 | 06:17 PM
gkz's Avatar
gkz
On mine, it was because the door was misaligned (hinge bushings worn).
Old Dec 2, 2013 | 08:27 AM
Easy Mike's Avatar
Easy Mike
...So the route to take is clean the gap, put adhesive in it and clamp it in position until the bond is cured?...
Yes.
...Wondering why this happens, just 33 year old adhesive finally givin'up?...
Yes.
Old Dec 2, 2013 | 11:13 AM
Roco71's Avatar
Roco71
I had that issue on my 71 at the bottom of the door. I used a paint stick and folded 150 grit sandpaper over it to clean up the old adhesive between the skin and the door frame before applying adhesive and using spring clamps.
Old Dec 2, 2013 | 04:19 PM
gkz's Avatar
gkz
Old Dec 2, 2013 | 08:50 PM
Postal123's Avatar
Postal123
the only thing I would add is rather than just clamp it, you should clamp it accordingly to set it at the proper depth/alignment. this may not be too much of a factor depending on where the separation has occurred...hope this explanation makes sense?
Old Dec 4, 2013 | 01:03 PM
Sunstroked's Avatar
Sunstroked
You will want to clean the disbonded surfaces really good.
Here is my experience with this problem. 72 corvette, fairly rust free desert car. Passenger door skin was disbonded in 2 areas. I first reattached using a hi strength epoxy made for bonding, evercoat maxim.
While adjusting the door fit on the body, 1 area again became disbonded. At this point I resigned myself to a full investigation. I removed the skin from the door. Found a 6" section where surface rust had formed andl prevented a good bond. In my opinion there was no other way to adequately repair my problem without complete skin removal. I probably could have re used the skin, but I am now waiting for delivery of a new panel.
I sand blasted the rust, cleaned and epoxy primed the entire door structure. I'm doing a body off restoration so paint match etc is not a problem. Just really look hard at your area of concern.
Old Jul 21, 2017 | 02:49 PM
bbrown450's Avatar
bbrown450
If you have the exceptionally vibrating door there is a service bulliten out, not sure what the number is b ur just had this taken care of by the dealer..problem gone
Old Jul 21, 2017 | 03:35 PM
Easy Mike's Avatar
Easy Mike
I'm confused. This thread is four years old and any service bulletin for a C3 is thirty five years old or older.
Old Jul 21, 2017 | 11:51 PM
RJ1AZ's Avatar
RJ1AZ
From: PHOENIX, AZ Yes, it's true. You are a good woman. Then again, you may be the Antichrist.
Alcohol and Corvette Forum surfing don't mix?
Old Jul 22, 2017 | 08:11 AM
midigike's Avatar
midigike
Duntov and Shinoda came out with a revision last year
Old Jul 22, 2017 | 12:00 PM
bj1k's Avatar
bj1k
Then glue and clamp overnight .
To Door skin separation
