Tire PSI
Old Dec 5, 2013 | 11:04 PM
Blessmyvette's Avatar
Blessmyvette
Default Tire PSI
I have an 82, inside the door it says that the PSI should be 15 in the front tires and 35 in the back. My husband says that's wrong. I don't know, but my gut tells me to do what the door says. Can anyone tell me what's the right way to go.
Old Dec 5, 2013 | 11:30 PM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
15 is too low. I run 32 all around in my 225/70 15's.
Old Dec 6, 2013 | 12:31 AM
Blessmyvette
At first I doubted my husband. Just makes since to me that the manual would know best, but 15 did seem really low. When I checked the tires myself and saw that the pressure gauge I was using didn't read lower than 20, that kinda confirmed 15 must be wrong. I just can't understand why would the manual say 15? What would cause that to change from 1982 to now? R was it always wrong?
Old Dec 6, 2013 | 01:06 AM
kdf1986's Avatar
kdf1986
I agree. 15psi is way too low. I keep mine at 32psi.
kdf
Old Dec 6, 2013 | 03:58 AM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
If there are wearing on the out side of the tyre on both sides to low If middle wearing to hard .I have 35 psi in mine but its a bb so would be bit higher .I have 32 psi in rear
Old Dec 6, 2013 | 08:08 AM
7T1vette's Avatar
7T1vette
Must be an error on the door sticker. At 15 psi, your front tires would fail at highway speeds, if run for very long. With low pressure, the sidewalls will flex too much when rotating and will generate heat...and then a blow-out.
Also, the C3 is front-end heavy. It wouldn't make any sense at all to put lower pressure in the front tires than you put in the rears.
I think 30-35 psi is about right for radial tires on the C3...depending on how firm you want the car to ride/handle.
Old Dec 6, 2013 | 08:31 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Blessmyvette
...Can anyone tell me what's the right way to go...
The right way is a pressure you like and are comfortable with.
Old Dec 8, 2013 | 09:50 PM
Blessmyvette
Thank you for the reply
Old Dec 8, 2013 | 10:04 PM
Blessmyvette
Thanks for sharing your knowledge on how to know if its too high or too low. Makes perfect since now that you've explained it. Common since actually. Guess common since isn't as common as it use to be.
I am learning. Thank you for your time.
Old Dec 8, 2013 | 10:24 PM
Blessmyvette
Also, the C3 is front-end heavy. It wouldn't make any sense at all to put lower pressure in front tires than you put in the rears.
Thanks to you also for sharing your knowledge. Seems like just common since after reading what you wrote. Like in my reply to sug, I guess common since isn't as common as it once was.
I have so much to learn
Just curious, what does it say your pressure should be on that sticker inside the door of your 71?
Old Dec 9, 2013 | 12:55 AM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Tire manufacturers will detail PSI and other information (weight capacity/date of manufacture, etc) on the sidewall of the tire.
Their individual websites usually provide like information to each model/style of tire. Consider that they spend more resources than any of us, determining the tires capabilities. Since tires are consumables, I would trust the tire manufacturer first, with their own current data.
My .02.
Good luck. Be safe.
Old Dec 9, 2013 | 10:25 AM
68L79's Avatar
68L79
Found my orig 68 owners manual.....and on page 47, it says
24 front.....24 rear
I run about 32 in front and 26 or so in the rear with radials....the figures 24/24 were with a nylon tire F70-15.
Tires usually show a MAX...not what is recommended by the car mfg. The car mfg knows more than anyone what the tire pressure should be...they are the ones that designed the suspension with all its geometry for that particular car and they are the ones that test the vehicle as to all its needs....then recommend the tire and its pressure....and I will add that by building 3 street rods from the ground up....the GM front suspension clips cannot be matched by any outside mfg.
Old Dec 9, 2013 | 10:37 AM
Mike Ward's Avatar
Mike Ward
Be aware that tire size and construction changed dramatically over the years, and today's tires are in some cases very different from the originals, so what might work for an 82 might not work for a '71.
Would it be possible to see a pic of your tire pressure sticker? I know of no Corvette, or any other car, that used 15 psi tire pressure.
To Tire PSI
