Radiator support bracket
Old Dec 24, 2013 | 07:54 AM
SB64's Avatar
SB64
Default Radiator support bracket
DOES ANYONE OUT THERE KNOW WHERE THE PART NUMBER FOR THIS BRACKET IS, OR IS THERE ONE. AIM SHOWS A NUMBER JUST CANNOT LOCATE IT. THANKS
OH FOR A S/B 4spd NO A/C 69
Old Dec 24, 2013 | 07:58 AM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
Roger,
What are you trying to do, replace it?
Terry
Old Dec 24, 2013 | 08:02 AM
SB64's Avatar
SB64
Default radiator
I am not sure yet. cooling system not right. Need a Alum. Rad. not sure if it goes in the support I have. Have the right fan, expansion tank, but not sure of the support.
Old Dec 24, 2013 | 08:13 AM
HOOAH's Avatar
HOOAH
I'm not at home to check for you but I have the same car. I cross-checked on the web and came up with this number; OEM Part #: 3966594 but again do not now where it would be located on the support itself. If you look at many of the vendors listings, you "may" be able to match it by visual reference to see if you have the right one. Have to be carefull because some of the listings may just be a generalized picture and not really the exact one. May be better to search by the part number and possibly find one someone is selling that has a picture of it.
The real reason for my question back to you is that I have replaced mine with a new one. My old one is probably useable if you wanted it, you are more than welcome to it. There is some bondo accross the bottom lip but I never chipped it out to see what was under it. Could be welded or fixed again if you wanted to go that route.
Oh and no charge for the support but I wouldn't be able to get it out till about the 2nd week in Jan.
Terry
Old Dec 24, 2013 | 08:47 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Radiator bracket or fan shroud bracket?
http://www.google.com/webhp?nord=1#n...+1969+Corvette
Old Dec 24, 2013 | 01:55 PM
SB64's Avatar
SB64
Default radiator
Radiator bracket. I have one on car know, just cant seem to find a part number, may be aftermarket for all I know.
Old Dec 24, 2013 | 02:04 PM
Alan 71's Avatar
Alan 71
Hi r,
What part are you calling 'support bracket'?
The aluminum radiator bottom has 2 'pegs' that fit into small round rubber bushings that fit into 2 small brackets that are part of the core support.
The top of the radiator is held by a single bracket in it's center with a rubber bushing that bolts to the top surface of the core support.
Regards,
Alan
Old Dec 24, 2013 | 02:15 PM
HOOAH's Avatar
HOOAH
Originally Posted by Alan 71
Hi r,
Regards,
Alan
I agree. After seeing easymike's post, I started wondering if it is the "bracket" (that holds the radiator to the support) or the "support" (that the radiator rests against and mounts to with the two rubber bushings at the bottom) you're looking for.
Terry
Old Dec 24, 2013 | 03:27 PM
SB64's Avatar
SB64
Default radiator
Confusing it is. expensive yes. Oh what a wonderful day. anyway the piece in the AIM marked#1 support assm. 3966591. where the h_ l l
is that number. please don't ask me if I am having fun yet. MERRY CHRISTMAS to all of the forum members
Old Dec 24, 2013 | 03:29 PM
SB64's Avatar
SB64
Default radiator
I think that Dewitts will work for a radiator, new it should work. penny wise a penny foolish.
Old Dec 24, 2013 | 04:49 PM
DonnieP73's Avatar
DonnieP73
Is this the part you are looking for?
http://www.ecklerscorvette.com/corve...1969-1972.html
Donnie
Old Dec 24, 2013 | 04:56 PM
Alan 71's Avatar
Alan 71
Hi r
3966591 is the core support.
I believe there are 3 core supports in 69:
one for the aluminum radiator
one for the 26 1/2" copper radiator
one for the 27 1/2" copper radiator
If you want a new reproduction support try Coffman Corvettes.
Regards,
Alan
Old Dec 24, 2013 | 06:08 PM
SB64's Avatar
SB64
Default radiator
Hey Alan I never heard of Coffman just emailed some info on what I was doing and they have the exact looking part. Thank you and thank you to Doonie for Ecklers. I always forget about that vendor
Old Dec 24, 2013 | 10:34 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
http://www.dewitts.com/collections/c...minum-radiator
Old Dec 26, 2013 | 08:18 AM
Easy Mike's Avatar
Easy Mike
There are two "brackets". One mounts the radiator. The second mounts the fan shroud. The AIM shows both.
To Radiator support bracket
