Headlight adjusters?
Old Jan 15, 2014 | 05:43 PM
alconk's Avatar
alconk
Default Headlight adjusters?
Has anyone used the correct black headlight adjusters and had them crack on you while screwing in the screw? Well I bought 8 of them and 6 cracked on me. Contacted the vendor and were great about getting new ones to me but don't want them to crack either. So what's the trick? I was using the yellowish nylon ones and seem a little thicker where the screw goes but would rather have the originals.
Old Jan 15, 2014 | 05:48 PM
Alan 71's Avatar
Alan 71
Hi a,
Are you certain the screws you're using are sized properly for the adjusters you're using?
Regards,
Alan
Old Jan 15, 2014 | 06:08 PM
alconk's Avatar
alconk
Well they came from the same vendor and look just like yours. Beautiful car by the way.
Old Jan 15, 2014 | 07:03 PM
Alan 71's Avatar
Alan 71
Hi a,
O.K. then.
Is the headlight 'cup' free to move? If it isn't, the screw may be putting too much pressure on the adjuster and breaking it.... maybe?
Regards,
Alan
I guess it's always possible that the material the adjuster is made from is not of good quality.... wouldn't THAT be a surprise!
Old Jan 15, 2014 | 08:12 PM
alconk's Avatar
alconk
Well after I broke the first two I decided to run the screws in while holding the adjuster in my hand and they still broke so I'm not sure.
Old Jan 15, 2014 | 08:41 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Al..
I don't know if you got them from me or someone else.. but tomorrow, I'll pull a set out of stock and run the screws in and out and see if I have the same issue...
Send me an email to Support@Willcoxcorvette.com.. I'll let you know what I find out.
If there is an issue, I'd surely like to know about it. I don't want us selling stuff that won't work.
Willcox
Old Jan 16, 2014 | 11:48 PM
Sunstroked's Avatar
Sunstroked
Coincidence. Im getting ready to place an order for headlight bushings, bearings and adjusters. I modded the headlights to electric and tore down the HL's today. Don't need the screws for the adjusters so I was going to buy just the black ones.
To Headlight adjusters?
