gas mileage
Old Jan 20, 2014 | 11:50 PM
Blame's Avatar
Blame
Default gas mileage
Had some reject make a statement about carbs making 14 mpg.
I know for a fact my 81 does 18 mpg avg. And ill improve on that in the coming months.
So how good is your gas mileage with a carburator?
(I AM NOT WORRIED ABOUT MY GAS MILEAGE, IM ONLY COMPAIRING MY MILEAGE TO OTHERS BECAUSE IM CURIOUS)
Old Jan 21, 2014 | 12:01 AM
harris1507's Avatar
harris1507
I have a 502 and a Holley 850 and I get about 6-9 mpg. (maybe) If I drive easy, but it is hard when you have a car with this kind of power.
Old Jan 21, 2014 | 12:35 AM
John 65's Avatar
John 65
454 with a Holley 750 DP. 10 MPG, but I cant complain, its fun to drive.
Old Jan 21, 2014 | 12:44 AM
CanadaGrant's Avatar
CanadaGrant
My bone stock 69 427 4 spd gets about 9mpg. My wifes 78 L82 auto might get 16 on the highway on a good day, downhill....
Old Jan 21, 2014 | 12:50 AM
ddawson's Avatar
ddawson
Who cares. My 2004 GTO after mod was only getting 10 in town and 20 highway.
My 84 Mustang with a Holley got better.
Old Jan 21, 2014 | 02:07 AM
7T1vette's Avatar
7T1vette
Fuel mileage is more related to the size of engine, the rear axle ratio, and whether it has an overdrive transmission and lockup on the tranny than anything else. Any carb in decent condition can be tuned to provide nearly the same mileage as if the car were computer controlled EFI. But, most carbs aren't tuned that well.
A SB C3 with O/D and 3.55 or lower rear gear should be able to get around 20 mpg at highway speeds.
Old Jan 21, 2014 | 05:58 AM
terrys6t8roadster's Avatar
terrys6t8roadster
my 68 roadster has been known to get around 5mpg on the track, and if I try real hard I've gotten 16 on the highway. it's a 350 411rwhp overdriven with 373screws. Been waiting for someone to post about mileage. onto the 69 coupe, L46 auto and 3.08's. option loaded. [this type of car must be rare cause you never see 69 base coupes for sale on the forum]. took the replacement rodchester off and installed a spreadbore, now getting 21mpg on the hyway and 18 normal mix driving. planning more mods [electric fan, overdrive trans]. hoping to see around maybe 27mpg. how are other CF members doing and what mods are you doing?
Old Jan 21, 2014 | 06:03 AM
Blame's Avatar
Blame
LoL so low of mileage.
Old Jan 21, 2014 | 06:30 AM
oldschoolvette's Avatar
oldschoolvette
don't care fun is the real payoff in this matter
its about smiles/gallon and that number is quit large
Old Jan 21, 2014 | 07:02 AM
Blame's Avatar
Blame
I care because I like improving on my vette performance and gas mileage.
Old Jan 21, 2014 | 07:58 AM
harris1507's Avatar
harris1507
In that case I get 100 smiles per mile
Old Jan 21, 2014 | 08:06 AM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
I check mine all the time. My car is a stock 350/270, 4speed with 3.36 gears and I get between 12 and 18 mpg.
Old Jan 21, 2014 | 08:49 AM
Revi's Avatar
Revi
You're getting more performance and more gas mileage? That's interesting. Let us know when you get 500hp/500mpg.
Old Jan 21, 2014 | 08:56 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Which proves that Corvettes were built for speed (and "gas stations")
don't care fun is the real payoff in this matter........its about smiles/gallon and that number is quit large
Which proves that Corvettes were built for F U N !
Which proves that anything can be improved...even mpg in a Corvette.
I started with a 1934 pickup (same weight as Corvette) 350ciSBC(stock)15mpg w/any type transmission 3.43 diff. gears 90*F
added Holley 600CFM carb (out of box) 15mpg engine-vacuum 13 "lbs."@60mph@3000rpm
rejetted Holley (2 sizes smaller on all jets) re-timed engine 16mpg vacuum 14lbs.@60mph@3000rpm
added CAI 18mpg vacuum 15lbs@60mph
removed P/S and steel fan/added electric fans 20mpg vacuum 16lbs.@60mph@3000rpm
added 700R4 A/T 22mpg vacuum 15lbs.@60mph@2400rpm
removed 3.43 diff. gears/added 2.92 gears (bad mistake--should have added 3.08 or 3.18 gears) still 22mpg vacuum 12lbs.@2100rpm@60mph***
***Basically I reduced engine rpm about 20%(a good thing)...BUT...I also decreased vacuum about 25%(a very BAD thing)...If I would have been able to maintain 15lbs. vacuum--the mpg would have increase 2 or 3 mpg. (I will install 3.08 gears at the next opportunity)
I will keep a record in my project thread of my Corvette engine readings as I make changes (for those who want better mpg for long trips (and still want to spin the tires for fun...LOL)
You guys with the beast-engines...just keep having fun!
Old Jan 21, 2014 | 09:28 AM
Roco71's Avatar
Roco71
My 1971 350 gets about 14 MPG -15 MPG
Old Jan 21, 2014 | 09:37 AM
bashcraft's Avatar
bashcraft
6-9? My 502 with the Holley 850, 3.55 gears and M20 got 13 mpg. I now have 3.08 gears and it still gets 13 mpg.
Old Jan 21, 2014 | 09:44 AM
Blame's Avatar
Blame
Starting to love my small block even more
To gas mileage
Old Jan 21, 2014 | 09:56 AM
diehrd's Avatar
diehrd
430 hp / 3.92 gears .700R4 .. 15 to 16 mixed driving , I do have to point out in my City you get town to town by expressway so I am on the highway a lot.
Old Jan 21, 2014 | 10:33 AM
Garys 68's Avatar
Garys 68
68 small block, big cam, 4 speed, 3.08 rear, about 14mpg.
Swapped in a 6.0 LS motor, Richmond 6 speed 26mpg hiway.
Old Jan 21, 2014 | 10:34 AM
Blame's Avatar
Blame
LoL nice jump in power and mpg
