power steering leak
Old Feb 9, 2014 | 05:51 PM
llabesab7's Avatar
llabesab7
Default power steering leak
found a leak coming from under the left front end near the right of the wheel. I know its the power steering. Looks like its dripping off of a hose or is there something else. Its not coming from the pump. I had to add fluid. It leaks pretty good. Is it an easy fix? Bill
Old Feb 9, 2014 | 06:38 PM
JimT's Avatar
JimT
One of the hoses is a low pressure hose and is secured with a clamp. Easy fix - may just be a loose clamp or a bad hose end. The other hose is high pressure and has factory/shop installed fittings. May have to replace the entire hose. Not a bad job, just messy. You will have to drain the power steering system.
Good luck..
If you do have to drain the steering pump, remember to refill with fluid, start the engine, turn the wheels all the way left, then right several times to "bleed" the air out of the lines.
Old Feb 9, 2014 | 06:43 PM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
Get under the car and have somebody turn the wheel while the engine is running and the e-brake on, you'll find the leak..
Old Feb 9, 2014 | 08:49 PM
lvmyvt76's Avatar
lvmyvt76
be careful here on getting under a running car or even just a car jacked up.
Old Feb 9, 2014 | 08:53 PM
Redwing01's Avatar
Redwing01
2015 C3 of Year Finalist
Old Feb 9, 2014 | 08:58 PM
briankeery's Avatar
briankeery
I've actually gone so far as to put old mirrored tiles under the car to source problems instead of getting in there.
Old Feb 9, 2014 | 09:22 PM
llabesab7's Avatar
llabesab7
I'll let my mechanic deal with it. Thanks for your help. Bill
Old Feb 9, 2014 | 09:36 PM
Mick71's Avatar
Mick71
Good idea.
To power steering leak
