Where can I get this bracket?
Old Feb 22, 2014 | 06:40 PM
tyrant's Avatar
tyrant
Default Where can I get this bracket?
Where can I find this bracket? I ordered one and doesn't look the same. This is my motor. It's a 1970. When I got it he bracket was removed. Thanks
Old Feb 22, 2014 | 07:05 PM
LT-1 kid's Avatar
LT-1 kid
corvette central sells them, get there catalog.
Old Feb 22, 2014 | 07:21 PM
loup68's Avatar
loup68
Army
They are a BIG buck! Ouch! Lou.
Alan 71's Avatar
Alan 71
Hi t,
There are 2 different brackets… one for q-jet carbs and another for Holley carbs.
Did you order the right one?
Regards,
Alan
Old Feb 22, 2014 | 07:27 PM
tyrant's Avatar
tyrant
I bought the Holley one. Not the same.
Old Feb 22, 2014 | 07:37 PM
Alan 71's Avatar
Alan 71
Hi t,
I'm not sure which sb 70 engine had a cast iron intake and a Holley.
Is this an engine with some 'other' parts installed on it?
Perhaps part of the problem is the linkage on the carb not being suitable for use with a stock bracket.
Regards,
Alan
Old Feb 22, 2014 | 07:54 PM
tyrant's Avatar
tyrant
It's a CTH engine code. Maybe it should have had a Q-Jet
Old Feb 22, 2014 | 08:57 PM
TimAT's Avatar
TimAT
That same bracket on my 69 was on the original tri-power, then a host of Holley and Demon carbs. And that's not even counting the 2x4bbl Edelbrocks. Worked everytime.
Old Feb 22, 2014 | 11:25 PM
Alan 71's Avatar
Alan 71
Hi,
Here's the q-jet bracket.
Regards,
Alan
Old Feb 23, 2014 | 09:47 AM
tyrant's Avatar
tyrant
Looks pretty close.
Old Feb 23, 2014 | 11:33 AM
Alan 71's Avatar
Alan 71
Hi t,
Yes, the bracket is close but look how DIFFERENT the linkage on the carb is.
Regards,
Alan
Old Feb 23, 2014 | 01:58 PM
7T1vette's Avatar
7T1vette
Appears to be the same bracket.
Old Feb 23, 2014 | 03:17 PM
Cavu2u's Avatar
Cavu2u
Tyrant,
Here's what my Q-jet SB bracket looks like, after I painted it orange.
Steve
Old Feb 23, 2014 | 07:01 PM
tyrant's Avatar
tyrant
Looks to be what was on there. I ave the correct intake but the Q-jet was replaced with a Holley and a adapter plate. I have to return the Holley one going to try the other.
Old Feb 24, 2014 | 01:05 AM
gbvette62's Avatar
gbvette62
"CTH" is the late 70 suffix code for the L46 350/350. This engine originally came with a cast iron intake, and a Q-Jet carb.
The Holley accelerator cable bracket was designed to be used with the production Holley carbs, on aluminum intake of the LT-1 (among others).
I think your problem is more than just the Holley carb. The adapter may be causing part of your problem, because of how it places the carb in relation to the intake and the cable. It's hard to tell from the picture, but it looks like you have the wrong cable also. All 1970 Corvette engines used the same accelerator cable, that attached to the carb, by snapping onto the ball on the carb linkage. In your picture, it looks like the cable on your car, is slotted on the end that attaches to the carb linkage. If you look at the picture that Alan posted, the end of your cable, should look just like his, and attach the same way. If you do have the wrong cable, this could be contributing to your problem with the bracket too.
Holley made a direct replacement "Spread-Bore" carb, to use on the Q-Jet intake, and from what I've seen, those carbs work with the Q-Jet bracket. The Holley Spread-Bore mounted directly to the stock Q-Jet intake, without the need for an adapter.
Old Feb 24, 2014 | 06:42 AM
Cavu2u's Avatar
Cavu2u
Afraid I muddy'd the water here myself.
Circled is the Part Number (3992386), but underlined is the name of the Edelbrock non-stock manifold (PERFORMER).
Some of the brackets available are shown at the bottom of the page here.
http://www.gmpartswiki.com/getpage?pageid=93511
Old Feb 24, 2014 | 09:41 AM
gbvette62's Avatar
gbvette62
The bracket pictured, 39923896, is the correct accelerator cable bracket for the 68-73 Corvette, with a Q-Jet. It was used on both small blocks and big blocks.
The bracket for the Holley was part number 3972627, and was only used with the Holley carb on 68-69 L-88's, 70-72 LT-1's and 71 LS-6's. The Holley's on 68-69 3x2 427's, used a completely different bracket (3921613), that was "V" shaped and bolted to both mounting studs on the left side of the rear 2bbl carb.
Mid-years used an accelerator rod, instead of a cable, so they didn't need a bracket.
None of the brackets, are available from GM anymore, but all of them are being repro-ed. The list price for the Holley and Q-Jet brackets, when they were discontinued about 6-7 years ago, was around $42. At $29 each, the repro's not cheap, but it's a better deal then $42. I don't think the repro's have the part number stamped in them though.
To Where can I get this bracket?
